Tightening top nut of a coilover
Old Mar 5, 2011 | 02:23 PM
1llusive's Avatar
Hi all. I'm getting a clunk from my front stance gr + pro coils. First thing I tried was to tighten the top nut but I'm finding that this was turning the shock shaft as well. Any ideas how to do this properly? Thanks a bunch!
Old Mar 5, 2011 | 02:32 PM
kyoo's Avatar
you need a special tool.. or an impact gun (not recommended)
Old Mar 7, 2011 | 10:42 AM
boomn29's Avatar
Some use the rubber & vice-grips method. Clamp onto the shaft carefully using rubber as an insulator so there's no damage. Then loosen the top nut. G/L.
Old Mar 7, 2011 | 10:55 AM
sharkm87's Avatar
impact gun
Old Mar 7, 2011 | 12:03 PM
GTWORX.com's Avatar
strap wrench.
Old Mar 7, 2011 | 12:42 PM
Smike's Avatar
Originally Posted by sharkm87
impact gun
Bad idea. Well, good idea if you want to shake and jostle the crud out of the internal valving or spin the piston so fast it creates enough gravity to support a small orbital of bolts and nuts.
Old Mar 7, 2011 | 12:47 PM
Evoardo IX's Avatar
Don't use an impact gun. Post pics of how the top strut nut looks like so we can help you further. On another note, are you sure that's the cause of the noise? It could be the spring too, when it doesn't freely rotate on the collars, you can fix that by installing some Coil-Over Shock Thrust Bearing. http://www.summitracing.com/parts/HA...-109/?rtype=10
Old Mar 7, 2011 | 01:15 PM
chu's Avatar
chu
If the threaded portion is long enough, use two nuts and lock them against each other, and use the to hold the shaft still...like you would do to a manifold stud. I've done that and it works very well. The top nuts really don't require a lot of torque.
Old Mar 7, 2011 | 01:52 PM
kyoo's Avatar
actually to be honest i used an impact gun for the rear lol. it did spin the piston a little but it was brief. whether i've done permanent damage remains to be seen i guess?
Old Mar 13, 2011 | 10:16 PM
never2low's Avatar
With a lot of coils you can take the adjustment knob off and put an allen wrench in the hole as well to secure the threaded part, I've never owned stance before though
Old Mar 14, 2011 | 12:28 PM
GTWORX.com's Avatar
i don't recommend to use the adjuster to hold the shaft.
Old Mar 14, 2011 | 08:26 PM
never2low's Avatar
I'll start off by explaining that all of my experience is with Megan Racing coilovers, but the megan racing website does actually instruct you to tighten the nut by putting a closed end wrench around the nut and a hex tool in the hole where the adjustment knob is. It doesn't go down into the adjuster, it just goes into the metal shaft above the adjuster.
http://www.meganracing.com/tech/faqs...m%20coilovers?
Rom
Sep 15, 2014 10:43 AM
tcarretti
Aug 18, 2011 09:21 PM
I4UnderPressure
Jul 6, 2011 08:18 AM
80210
Apr 22, 2008 09:19 AM
Profoxcg
10
Nov 28, 2007 12:28 PM
