Brake Caliper rebuild
What kind of valve stem are you referring to? I just changed my brake fluids and don't want to lose what's in there when I redo my caliper seals... I'm getting brake drag after I flushed old fluid out
How to guide
I just did this project yesterday and wrote a very detailed how to guide with lots of pictures to hopefully make this easier for the next guy. It goes over rebuilding the calipers as well as painting them. Check it out here on DirtyEvo; I hope this helps! Rebuilding and Repainting Brembo Calipers - DirtyEvo.com
so after doing a brake job and bleeding my brakes, I noticed my pedal still went to the floor unless I pumped it. for some reason I was stupid and replaced the brake master cylinder
turns out my upper pistons are failing on one of my brembo's in the front, and the other one needs a rebuild kit badly
will the rebuild kit fix my issue or is that caliper done?
it looks like fluid is leaking out from behind the failing pistons. is this just a seal that needs to be replaced?
Tia
Tia
even if we rebuild with the seals, aren't they just gonna fail again after another few track days? anyone here offering a rebuild and repaint service for brembos?
FWIW: Centric seal kit for 1x caliper, $7.56
http://www.rockauto.com/en/moreinfo....423022&jsn=338
thecarfreak
Oct 13, 2017 06:31 AM
jingalalahoe
Sep 9, 2016 12:44 AM
Treyzian
35
Mar 31, 2016 10:36 PM
356, brake, brembo, caliper, calipers, evo, evolutionm, kit, leaking, rebuild, rebuilding, refurbishment, seals, tcc, works
