softer springs
Old Jan 10, 2004 | 04:16 PM
c5racr1's Avatar
softer springs
what brand and type of spring will make the evo ride softer, kinda like the sti? I have back problems and love the evo, but need a more forgiving ride.
Old Jan 10, 2004 | 04:24 PM
bobaab's Avatar
the only thing you can really use are coilovers, springs in general lower your car giving it a worse/stiffer ride. you'll be able to control the stiffness of your ride if you got full coilovers though.
but if u've had back problems prior to owning an evo, i think u made a bad choice in cars. sorry to hear about your problems tho
Old Jan 10, 2004 | 04:34 PM
chronohunter's Avatar
Re: softer springs
One of the easy things you could do is go to a softer constructed tire like the Yoko ES100. A tire can make a big difference in ride quality especially since the Advans are so stiff. You will give up some performance, especially steering sharpness
Old Jan 10, 2004 | 04:44 PM
bluevilevo8's Avatar
Go to a 16 inch rim and a larger side wall.
Old Jan 10, 2004 | 05:34 PM
Crazy4Cars's Avatar
Re: softer springs
Before having the Tein Flexes, I had the Tein Stechs lowering springs, ride was very good, much better that stock, not bouncy and even my wife noticed the change, let alone the new look of the car.
Old Jan 10, 2004 | 05:48 PM
c5racr1's Avatar
my back got bad after I got the evo, How will the coilovers help the ride?
Old Jan 10, 2004 | 11:19 PM
wlelandj's Avatar
I had Cusco Zero-2R's on my WRX and loved them. I had a 8K/5k set-up (7/5 "stock") with spare 7&6k fronts and 4k rears. When I went on an extended highway drive I'd set them on 1 (out of 5) and it was almost plush. I always meant to drop down to a 6/4 setup (lowest recommended rates) for a better road ride ride (read the wife ) and a little more flexibility with the dampening from 1-5 but I never got around to it (I was too pleased with the handeling as it was and didn't want to screw it up). i'd bet with a 6/4 set-up it's be a soft or softer than stock on "1", but you'd have the ability to firm it up when you wanted to.
-Leland
Old Jan 10, 2004 | 11:28 PM
Lowness's Avatar
yea i'm having back problems too because of the evo. I have to go to a chiropractor 3 times a week for back therapy. The doctor said i might have shattered one of my lower spinal disc.
Old Jan 11, 2004 | 09:18 AM
instigator's Avatar
I hear Accords have a real nice ride.
Old Feb 24, 2004 | 07:29 PM
Conduit's Avatar
-Leland
I run 6/4 on my WRX Cusco Z2Rs with 2 dampening in front and 1 in the rear. I find the ride to be very good most everywhere. Sure, sometimes the ride is too stiff, but my gf often comments that she really feels safer in my car as its setup now.
It took me a while to really tweak the ride heights to get optimum balance, but in the end, it is about as good as it gets, frankly.
I seriously doubt that any coilover, however, is going to soften ride up more than stock. Getting rid of flexible strut mounts is not something you do for comfort purposes
Old Feb 24, 2004 | 07:32 PM
93civEJ1's Avatar
i like the Stech's.
Old Feb 24, 2004 | 07:39 PM
Shahul X's Avatar
check out the spring rates thread.....
-shahul
Old Feb 24, 2004 | 09:10 PM
Tri-Bar's Avatar
I would have to say for what you want , The Eibach Pro-Kit would work best , they are progressive. Soft under normal driving, But get firmer under harder cornering. Good luck.
Old Feb 24, 2004 | 09:12 PM
grasshopper's Avatar
buy a crown vic!!!!
Reinhard
Nov 26, 2013 03:16 PM
cetinsaya
17
Apr 26, 2006 09:17 AM
EvoRSfor060
Aug 27, 2005 09:59 AM
Michael Adair
Apr 1, 2004 09:01 AM
turbonawd
12
Nov 6, 2003 04:43 PM
