Single best handling modification CT9A.
Old Mar 2, 2012 | 11:00 AM
FX11's Avatar
Originally Posted by bayrider
The best handling mod for me IMO is the rear diff plate swap. I just got this done last week and it made me fall in love with my car again.
i will be doing this for sure once it gets a little bit warmer. Theres snow outside lol
Old Mar 2, 2012 | 11:10 AM
Dallas J's Avatar
Veteran: Army
Ignoring the already said driver mods,
Rear diff
Trailing link bushings
Front sway bar
Front lower control arm bushings.
That would be my path (though bushings are cheap enough that I might even do those first).
Front sway bar would be done during a clutch job if possible, I did it by itself and its quite the B*tch to do.
Old Mar 2, 2012 | 11:21 AM
CAD EVO's Avatar
My Bilstein HDs with Swift Spec R's make my car so much more enjoyable.
Edit: Just read you already have my strut & spring setup. sorry for the clutter!
Old Mar 2, 2012 | 11:22 AM
SyZyGy1394's Avatar
GG06MR's Avatar
Originally Posted by CtSilver03Evo
Hey guys,
I was just wondering what single modification has the best effects on handling for the Evo VIII/IX CT9A chassis? I currently have an MR, so I have the Bilstein struts, and I put some Swift Spec-R springs on it. I also have a set of Volks with Nitto Nt555 Tires on it. Everything else suspension-wise is stock.
What mod can I do that will have the biggest gain in handling for a weekend warrior street car?
Thanks!
A top notch set of coil-overs with spring rates appropriate for what you're wanting to do with it.
Old Mar 2, 2012 | 12:00 PM
mouseIX's Avatar
Originally Posted by BriK
1. Driver mods
2. Driver mods
3. Driver mods
4. Car mods
Couldn't agree more!
Old Mar 5, 2012 | 05:20 AM
CtSilver03Evo's Avatar
Thanks everyone for the input. I just came back to this thread for the first time since I posted it a couple of days ago and was surprised to see how many people posted. I have kind of neglected this part of the forum and pretty much always focused on making my car faster... Can someone share me a link to update me on what the rear diff plate mod is? Thanks!
Old Mar 5, 2012 | 05:47 AM
mouseIX's Avatar
I'm pretty sure it's a sticky. And the search engine will blow up if you try it, pretty popular subject.
Old Mar 5, 2012 | 05:49 AM
mouseIX's Avatar
Yep it's a sticky in the "Evo Engine/turbo/drivetrain section.
Old Mar 5, 2012 | 05:54 AM
Cool. Thanks again. I'll check it out.
Old Mar 5, 2012 | 03:02 PM
Ludikraut's Avatar
Rear diff
Front sway bar
^ This!!!
Rear diff was the best handling mod I made on my '03, followed closely by the Bilstein/Swift package (which the OP already has).
l8r)
Old Mar 5, 2012 | 03:16 PM
lan_evo_mr9's Avatar
Getting your acd reprogrammed is the cheapest, easiest and most effective single mod IMO...
I may be biased though
Old Mar 5, 2012 | 05:07 PM
griceiv's Avatar
I dunno, restacking the rear diff plates yourself is pretty darn cheap. (zero dollars)
Old Mar 5, 2012 | 05:12 PM
GG06MR's Avatar
Except for the new fluid you have to put in it, which costs more than zero dollars. Still, very cheap!
Old Mar 5, 2012 | 07:49 PM
Very true! The labor or time spent on the other hand is not so cheap! I agree that the diff plate mod is fantastic- it still boggles my mind how the factory did that
Matt
