Single best handling modification CT9A.
Hey guys,
I was just wondering what single modification has the best effects on handling for the Evo VIII/IX CT9A chassis? I currently have an MR, so I have the Bilstein struts, and I put some Swift Spec-R springs on it. I also have a set of Volks with Nitto Nt555 Tires on it. Everything else suspension-wise is stock.
What mod can I do that will have the biggest gain in handling for a weekend warrior street car?
Thanks!
Thanks!
There is no one "wonder part" for the Evo. Depends on your personal driving feel as well as what you're using the car for. Doing Auto X helps bring out the flaws in your car's suspension.
Getting the nut behind the wheel dialed in would be the biggest improvement!
Then.....good alignment, rear sway bar & rear trailing arm bushings @ the same time. i have seen numerous torn trailing arm bushings.
GL
GL
Spend whatever mod money you have on a good high performance or race driving school. A good driver can turn faster lap times in a Yugo than an average person in a heavily modded Evo or any other car for that matter.
x2 for driver mod.
once the driver is fixed look into a rear diff to get the car to rotate so you can put the power down harder coming out of a turn.
Brake pads would be next on my list.
Not really anyone one suspension item that you could improve to make the whole system better...
However, one could do the rear diff mod if you want more oversteer...
