Car has gangster lean! help! ideas!?
ok so i put a different (used ) strut on tonight and it is still leaning toward the drivers side the same. Any way the other side is bad if its sitting higher? I just figured the lower one was the worn out one. I think im going to pull that one out and just check it out. If i don't see anything.
Ill be buying new springs and ditching the tein h techs ..
Could be a defective spring, or install error. Do you still have the stock springs to put in and compare how it sits vs when you have the teins on there?
but ill get some new springs coming and go from there. When i "jounce" the front of the car it does feal like the pass side is springier and the driver’s side is stiffer. Almost like it’s doing the wave haha. You can feel it a little when you are driving also when you hit a bump that both wheels hit.
murkdevo
83
Oct 16, 2012 05:53 PM
Photool
Lancer Tranny/Drivetrain Tech
Feb 17, 2011 06:45 PM
