Extended wheel studs in rear
Old Mar 18, 2013 | 09:53 PM
JJsevol's Avatar
I've been looking at a few threads on installing extended studs. From what I've gathered looking at a thread I found: the user removed ebrake and then removed the 4 bolts off of the hub assembly and pulled the hub off a little.
Can't I just remove the axle nut and pull the hub off a little and then install the extended studs?
I think I'm going to need a after doing this
Update: definitely a PITA because there are so many parts to take off just to get to those studs. It took about 4 hours with some breaks in between. I took some pictures if anyone needs them.
Old Mar 18, 2013 | 10:08 PM
Sev's Avatar
Sev
I heard they're a real pain in the *** to install.
Old Mar 18, 2013 | 10:22 PM
JJsevol's Avatar
Yup that's what I've read so far, too. I'm getting the studs by Wednesday so hopefully it doesn't take long to install and I can drive the car by Thursday to get it aligned.
Old Mar 19, 2013 | 05:55 AM
chu's Avatar
chu
I've tried installing extended studs in the rear, and its definitely a pain. I removed the e-brake assembly and everything. You have to pull the hub off some to get enough room.
Old Mar 19, 2013 | 08:10 AM
JJsevol's Avatar
Thanks. I'll see how it goes.
Old Mar 30, 2013 | 09:30 AM
honda-guy's Avatar
replaced my one rear hub the other day. took about an hour.
https://www.evolutionm.net/forums/10726317-post12.html
i got some TougeFactory extended studs that where just short enough to get in without removing the rear hub. not sure what size they were though.
Old Mar 30, 2013 | 09:33 AM
honda-guy's Avatar
double post
Old Apr 2, 2013 | 10:12 PM
JJsevol's Avatar
I used the same ones. They are 50mm.
Old Apr 4, 2013 | 09:05 AM
Orion12's Avatar
damn i will be doing extended studs also.. im not looking forward to installing them =/
tim85851
Jan 16, 2026 08:11 AM
poonpower
Oct 22, 2016 06:35 PM
free ride
37
Mar 31, 2014 01:21 AM
p.phresh
Jul 22, 2009 11:34 AM
4no
Jul 16, 2009 04:27 PM
