Alignment Question
Old Jun 6, 2015 | 09:54 AM
R3VOLUTION's Avatar
Alignment Question
My Evo is dropped on GTWorx Springs, and I'm running 18x9.5 +22 Work CR Ultimates. Toe is fine but I can't seem to get my camber uniform on all 4 corners. Whats the best way to get a proper alignment without going to coils and using the top hats?
Old Jun 6, 2015 | 03:09 PM
LetsGetThisDone's Avatar
You need camber plates up front to dial in the camber perfectly. In the rear, depending on how much its lowered, the X's run out of adjustment and need a camber link. My friends is like this. The least rear camber he can get is -1.6 in the rear..
Old Jun 6, 2015 | 04:21 PM
R3VOLUTION's Avatar
I'd be fine at 1.6 all the way around, if I can get all 4 to do it.
Old Jun 7, 2015 | 07:52 PM
well, stock you only have the upper bolt of the two that hold the strut to the knuckle. And it's only 2 positions. So you need camber plates up front and you should be good. However, you will want more front camber than rear. If your running -1.6 in the rear, you'll want at least -2.5 up front for good handling characteristics..
Old Jun 8, 2015 | 05:14 AM
R3VOLUTION's Avatar
Sorry perhaps I need to clarify.
I'm not looking for aggressive or anything other than a simple alignment that won't kill my tires. Do I need all those bits for that? Honestly at that pricing for plates + bolts I'm halfway to coils.
Old Jun 8, 2015 | 05:52 AM
e_kobz's Avatar
The fronts are where you're gonna have a hard time because there's one bolt that dictates camber. The way it comes from the factory is in the -1 to -1.2 range. Rotate it 180* and its -2 to -2.2ish give or take. Been a while since I messed with it. The rears have more adjustment than the front. You can find camber bolts but I wouldn't trust them. Camber plates would be the way to go, that is unless you get coilovers.
Old Jun 8, 2015 | 10:14 AM
You don't have adjustment up front without camber plats, you simply have 2 positions of the upper bolt, and you get what you get. So either live with it not being perfect side to side, or buy camber plates..
Old Jun 8, 2015 | 10:33 AM
R3VOLUTION's Avatar
Well that sucks, but makes sense. I'm not particularly suspension literate if I'm honest. It looks to me like it would be better to just pick up a set of lightly used coils rather than plates. At least coils have solid resale value.
Old Jun 8, 2015 | 11:26 AM
Eh, a cheap set of lightly used coilovers is going to ride like pretty rough compared to your MR ohlins with lowering springs. I would do camber plates and call it a day.
Old Jun 8, 2015 | 11:36 AM
R3VOLUTION's Avatar
I was thinking something like KW3's would be good, but I do suppose it would be silly since I don't really want to be any lower. Suggestion on camber plates? Vorshlag?
Old Jun 8, 2015 | 12:00 PM
Vorshlag is quality. KW V3's you have to purchase camber plates separately, they're not included. Ohlins from Muellerized would be a good option in the same price range as the KW's, new..
Old Jun 8, 2015 | 08:20 PM
buzzzin_IX's Avatar
if your not trying to spend alot of money, a set of fortune 500 or BC racing spec are a couple of solid choices. many run the fortune's and like them alot.
dek0026
May 15, 2008 03:31 AM
purecoda
Lancer Troubleshooting
15
May 24, 2004 06:42 PM
MyEvo8you XP
Apr 24, 2004 09:43 AM
a904dam
Feb 18, 2004 06:10 AM
purecoda
20
Apr 29, 2003 01:31 AM
