Stripped Bolt on front subframe crossmember
Old Mar 31, 2016, 11:16 PM
k0lok0yboi's Avatar
Hi EvoM community,
I'm replacing the clutch but found that the bolt that holds the front subframe crossmember to the body of the car was stripped and doesn't want to come out. I assume it wouldn't be safe to drive but was wondering if it really was unsafe. Also any ideas on how to remove the bolt?
MinusPrevious (Apr 2, 2016)
Old Apr 1, 2016, 09:46 AM
Received 1,384 Likes on 1,317 Posts
Are you referring to the lengthwise member w/the roll stopper engine mount?
If so, that member certainly supports a lot of engine weight but if its still connected I would suppose it is OK until the issue is corrected
Try prying down on the member while trying to remove the bolts attempting to catch some clean threads
k0lok0yboi (Apr 1, 2016)
Old Apr 2, 2016, 12:03 AM
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
He can't get the bolt out Joe. I suspect it's the captured bolt with the nut on it spinning inside the chassis that lots of people have issues with.
OP, are you talking about the bolt that goes through the rear of the lower control arm, or the nut, which is threaded onto a stud towards the front of the subframe?
Old Apr 2, 2016, 05:05 AM
Sean, Sounded like this crossmember here
Old Apr 2, 2016, 07:57 AM
Oh, yeah. He could be. I guess we have to wait until he comes back lol
Old Apr 2, 2016, 08:28 AM
k0lok0yboi's Avatar
He can't get the bolt out Joe. I suspect it's the captured bolt with the nut on it spinning inside the chassis that lots of people have issues with. OP, are you talking about the bolt that goes through the rear of the lower control arm, or the nut, which is threaded onto a stud towards the front of the subframe?
Yea that's exactly what's happening. That bolt just spins; therefore, I can't get the subframe off the car. The best way I can explain what I'm talking about is that this assembly goes from the driver side axles to the passenger side axles. It's also what's directly underneath the center diff
Old Apr 2, 2016, 08:29 AM
k0lok0yboi's Avatar
No not that one. I meant the one that goes left and right
Old Apr 2, 2016, 06:56 PM
There is a thread in here somewhere. You have to cut the frame rail open to get it.
Here it is:
https://www.evolutionm.net/forums/ev...how-fix-3.html
Old Apr 3, 2016, 08:23 AM
Yeah, be careful & dont go to the extreme as the latest post did. He dropped a window into the wheel well which may not have been necessary
Try the heavy duty screw driver method first
Old Apr 17, 2016, 07:48 AM
myusernamesucks's Avatar
yes the wheel well window was my solution, and it worked. I had tried the screwdriver method however the bolt was still spinning so i had no other choice. Opened it up, put a vice grip on the head of the bolt and got the nut off. Also, even with the vice grips on the bolt, the nut was very hard to spin off the bolt, had to use a 4 foot breaker bar the whole length of the bolt =(
Old May 13, 2016, 09:35 PM
envyno1's Avatar
Sorry to thread jack but anyone know the part number for the bolt that goes to the chassis for the center member bracket?
MinusPrevious (May 14, 2016)
Old May 14, 2016, 06:00 AM
^^^ Here you go
envyno1 (May 14, 2016)
ClaudioEvoX
Sep 26, 2012 11:47 AM
dudical26
51
Sep 9, 2012 02:02 PM
RSGuy
Jun 25, 2012 01:38 PM
PDCC_EVO
Jan 10, 2012 02:20 PM
Quick Reply: Stripped Bolt on front subframe crossmember
