corner balancing - adjust preload or shock length?
Old Jun 27, 2017 | 01:18 AM
mrfred's Avatar
Typically, to get good CB on the evo, the passenger front, and driver rear coilovers need to be a few turns longer. You don't use preload for corner balancing. Preload isn't really something I've seen the need to use on the Evo. It's usually used to attain ride height when you want to run a softer spring, but most coilovers are ride height adjustable.
I was curious if there is a rough rule-of-thumb for an Evo. I'm currently installing new springs, so I might add an extra turn or two of length to the front passenger and rear driver corners.
Old Jul 4, 2017 | 07:49 AM
killerpenguin21's Avatar
my corner weight is off 4-5%, it is noticeable since it has "wedge" in the car if you wanna use nascar terms. unfortunately my ohlins are so old they are not shock body adjustable, so not much i can do about it.
M3this
West Region
Mar 5, 2006 12:42 PM
M3this
Mar 1, 2006 06:00 PM
hkfeet
Jan 18, 2005 12:03 PM
MrBonus
Jul 19, 2004 09:51 PM
evo 8 ya
Apr 12, 2004 09:42 AM
