kyoo
close
- Join DateMay 2006
- LocationUS
iTrader Positive Feedback100
iTrader Feedback Score(29)
Liked:283 Times in 244 Posts
after track day, clunking is back with vengeance in the right rear. i tightened the endlinks but no difference there. pretty awful, i'll check if it's the strut tops but otherwise that seems to be the only noise coming from the suspension now
Biggiesacks
close
- Join DateAug 2005
- LocationWest Coast
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:708 Times in 595 Posts
I don't know if you have, but it might be time to start looking into suspension bushings. Maybe too much play is causing things to get loose.
kyoo
close
- Join DateMay 2006
- LocationUS
it was a pretty stark before & after with the bar. i'll recheck bar position too but bar should be centered and back enough now..
kyoo
close
- Join DateMay 2006
- LocationUS
ordering the mcmaster carr set of endlinks
does the nylon lock washer need a washer behind it? pictures don't show it, i assume it should have one, aside from the cup shaped washer that i assume goes on the other side.
How are your coilover locking collars, they still tight?
Also hows the preload of the springs?
Yea everyone in a while mine will come loose. Blue loctite has helped.
kyoo
close
- Join DateMay 2006
- LocationUS
Quote:
i hope that's it, i'll post soonishOriginally Posted by CaptainSquirts
Quote:
Soonish he says Originally Posted by kyoo
.kyoo
close
- Join DateMay 2006
- LocationUS
lol hey i got a lot going on lol. luckily not my daily, i drive this car like once a month
Quote:
Jackstands for sure, you don't want the suspension loaded. You don't have to do all 4 corners, you can do one or two at a time, whatever is easier for you.Originally Posted by gerikivan
when you installed your endlinks is on jackstands or all 4 corners is in a ramps?
Quote:
thats not the right way to do it... one of my friend had the same issue because he installed the endlinks on jackstands...you want all 4 corners to be loaded.. here a link https://www.evoxforums.com/forums/ar.../t-147402.htmlOriginally Posted by Fox_IX
Quote:
Interesting. I've always done this on a lift without issues, but I did notice a recent clunk noise begin to appear on my IX. Anyone else have experience with this?Originally Posted by gerikivan
kyoo
close
- Join DateMay 2006
- LocationUS
it was corner balanced, loosened and tightened.
i'm assembling the new custom endlinks now. pretty straightforward, but did you guys put a washer behind the lock nut (so that it's not just the nut to the bar? seems like you should but he didn't have one on his
the other hing is that the eyebolts seem too long - but the parts i ordered were what he listed, in the images he seems able to insert his all the way, but i've got about half an inch before they stop because they're too long
