CBRD Tune ECUFlash
Old Jan 17, 2009 | 06:44 PM
  #31
SiC's Avatar
SiC
Originally Posted by STi2EvoX
So what do these tables use to calculate? Are they based on load, airflow over the maf, what? Could you post pics of the tables? That would be great, if you don't mind.
Both are RPM x Throttle based and the values seems like load but it's really hard to tell. Also, I believe that these are the maps that need adjustment to prevent the ASC light problems and other CELs.
Old Jan 17, 2009 | 09:41 PM
  #32
05mazdarx8's Avatar
Someone please fix my tune
Yes I did reduce myself to begging.
Old Jan 17, 2009 | 09:46 PM
  #33
STi2EvoX's Avatar
Thanks, that's what I was looking for.
Agreed.
On a side note, I am curious about one thing regarding limp mode; on most turbo cars, there is a boost cut value, but on the X it seems like limp mode is a more advanced form of this. Is there still a traditional boost cut value/table, or are the airflow check tables and torque limiter tables a replacement for this? I'm guessing the latter, but I would like to know for sure. Thanks.
Old Jan 17, 2009 | 10:27 PM
  #34
SiC's Avatar
SiC
There is a standard 2D boost limit map which is based strictly on RPM and the values are in load.
Old Jan 18, 2009 | 06:01 AM
  #35
gunzo's Avatar
I think it's actually 3 of each and the 4th is actually a reference table of some sort (no need for adjustments). Those are some weird tables, Airflow & Torque both share the same scale & values.
Actually non of them are airflow tables haha
And I have a rough idea how it works now .. but I still have no idea how #4 affects the others since we never had problems with that ..
I can load the exact same maps from the JDM to a USDM and the USDM car will throw a CEL within 1nm on boost ..
Old Jan 18, 2009 | 06:12 AM
  #36
SiC's Avatar
SiC
Doesn't ECUTek call these table Trustfull Airflow Against Torque and Trustfull Airflow Check? The scales and values are identical to the ECUTek maps. According to G/Force, you don't need to adjust these maps on a 5MT.
Yeah, we never have these issues with the JDMs even with the SST models.
Old Jan 18, 2009 | 06:42 AM
  #37
CBRD's Avatar
this issue is present for ALOT of people tuning the X's...
I have offered to reflash tim's car to stock while i sort out the issue, shouldnt take long...
cb
Old Jan 18, 2009 | 06:57 PM
  #38
Yearlongstorm's Avatar
Give CBRD a chance to correct it first. No need to beg for someone.
Old Jan 18, 2009 | 07:17 PM
  #39
gunzo's Avatar
Its a naming convention .. just like desired engine load is something I'm used to on the older Evos .. versus the ECUTek Engine Load thing ..
I chose airflow limiter .. and it seemed to have stuck
but the more I played with it and the more reports I get back .. it's actually not ..
Old Jan 18, 2009 | 07:49 PM
  #40
05mazdarx8's Avatar
Its just some friendly bantering to Chad so don't get your panties in a bunch
I have been in contact with Chad. I know he will come up with a solution.
Old Jan 19, 2009 | 12:06 AM
  #41
HB Speed's Avatar
Chad!
i think i have a solution!
hit me up !! !
Old Jan 19, 2009 | 08:11 AM
  #42
CBRD's Avatar
thanks jon,
i found something too!
cb
Old Jan 19, 2009 | 10:32 AM
  #43
STi2EvoX's Avatar
Well for the benefit of the community, please share! What is the exact fix for the issue? From what I know, most tuners that have been able to avoid the issue simply look at what loads the car is hitting after the tune, then go into the airflow/torque limiter tables and airflow check tables and just raise the values by a certain percentage. Is what you guys are doing now too, or is there something else?
Old Jan 19, 2009 | 10:45 AM
  #44
Sean@Iveytune's Avatar
How would anyone know what Ecutek calls it unless someone is divulging Ecutek info.
So this is what it comes down to now, referencing Ecutek info to find a solution for an Ecuflash issue?
I was always under the impression that the object of the Open ecu stuff was to do something seperate and apart of the Ecutek SW etc.
Well we have tuned a ton of evo 10s with Ecutek SW and these problems do not exist. They spent alot of time and money to make a seamless product that can be delivered to customers without "bricking" ecus.
Sean
  #45
HB Speed's Avatar
adjustment of those tables (which may or may not be a air/tq limiter)
has helped some but if you adjust too much it causes the same issue.
BDEL has to be adjusted as well and a few other little things
The biggest issues right knoware trying to figure out what these tables do and why. Most tuners just use an EBC or MBC and let the cel's happen. (car still runs pretty much the same)
Personally i think we will have this nailed down in a few weeks
