CBRD BB-X - E85 - +83 whp peak!
Old Jan 24, 2010 | 08:13 PM
  #31
mlomker's Avatar
Very similar to how my car will be plus MX1's, Full Race mani, and ported stock intake mani. I was thinking 450 so that should be pretty much in the ballpark.
Excellent.
Old Jan 24, 2010 | 08:15 PM
  #32
Clipse3GT's Avatar
Originally Posted by mlomker
single walbro or a double pump on this car?
d.p.
Old Jan 24, 2010 | 08:26 PM
  #33
mlomker's Avatar
Originally Posted by Clipse3GT
I'm sure you could up the base/idle pressure a bit to get a bit more flow out of the injectors if you had a adjustable FPR along with a higher output pump.
I'm going to be doing that on the 1000's for E85. We really need 1200-1300 injectors.
Old Jan 24, 2010 | 08:30 PM
  #34
Clipse3GT's Avatar
The only issue with that will be your idle... it will be a pita to get the correct latencies to get idle undercontrol and not have very negative idle ltft's.
Old Jan 24, 2010 | 09:10 PM
  #35
Hiboost's Avatar
1200cc drop-ins would be great but I guess if you want E85 goodness you have to sacrifice some plug and play. I think the Fuel Injector Clinic BlueMAX 1250-1650cc Injectors look like the next best bet although I want to confirm exactly what is needed to make them work 100% with the Evo X.
Old Jan 24, 2010 | 09:12 PM
  #36
Clipse3GT's Avatar
Would RC ENG 1200cc work?
Old Jan 24, 2010 | 09:13 PM
  #37
delkat's Avatar
Guys,
This is my car and I have to say it feels really good. On the freeway in 4th or 5th, boost builds strong in the 31-3300 range. I really didn't notice a difference in spool when I switched from the stock turbo.
I was impressed with the torque spike when I went from the 91 to E85 tune on the stock turbo but the power fell off sharply after 5500 and it was a little disappointing. Now the car pulls very strong and smoothly throughout the RPM range.
I agree with the comments about the cat and cams. I would probably need to do something with the injectors/FPR in order to add any more mods but I would love to try cams and/or a test pipe (resonated). The car is my daily driver so I don't want to impact the noise/drivability any more than I have. Right now it's very streetable and quiet. The engine compartment looks very OEM. I even made a flat black cover to replace the AEM intake "logo" cover.
I have 91 in the car now and after running through a tank we plan to get some dyno numbers on 91 for you.
The guys at GST, CBRD and Blaqops have been extremely helpful with this build. I had hip surgery in the middle of things so the results were a little delayed.
Old Jan 24, 2010 | 09:20 PM
  #38
pikkagtr's Avatar
hol crap that is a lot of power
Old Jan 24, 2010 | 09:29 PM
  #39
spdracerut's Avatar
I would keep the cat, and get cams. Going to a test pipe will make the car louder, and I'm a greenie at heart.
Old Jan 24, 2010 | 10:16 PM
  #40
HR2L's Avatar
Guys,
Super Jealous! Glad to see that your car is making some serious power now! You'll have to give me a ride in that beast!
Old Jan 25, 2010 | 12:47 AM
  #41
GST Motorsports's Avatar
Originally Posted by rogue
Anyway, do you have another customer lined up for an install with pump gas?
This same Evo 10 will be tuned on 91 oct soon like I mentioned in the first post.
- Bryan
Old Jan 25, 2010 | 01:41 AM
  #42
darwin_evo's Avatar
What is the CBRD WGA spring pressure??
Old Jan 25, 2010 | 02:19 AM
  #43
E6-X's Avatar
time to get 1000 cc inj's, double pumper, at least water inj (can;t get meth or even washer fluid where i'm at ! sux big time !) for this beast ! can't wait to see the results on pump gas ! but the main prob for me would be TQ cos of sst
Old Jan 25, 2010 | 05:29 AM
  #44
mlomker's Avatar
I think the Fuel Injector Clinic BlueMAX 1250-1650cc Injectors look like the next best bet.
MAP sells them with pigtails or optional adapters for another $50. I'm going to ask my tuner what he thinks. My quick math suggests that 1350's would be adequate. This will be my THIRD set, though, so I'm inclined to go a little big than a little small (again).
Old Jan 25, 2010 | 07:01 AM
  #45
scheides's Avatar
EvoM Moderator
Frankly I have mixed emotions. This is only ONE car (and I cannot wait to see more results) but CBRD mentioned gaining torque, not loosing it like the FP Red vs the stock turbo. The power is definitely there though, this is a wicked turbo, perfect for a stock-appearing setup. 450whp on this dyno with cams and no cat should be cake on E85.
I wonder how much boost this thing will actually hold up top, 30+psi would make a more power for sure, but seeing this done on 28psi is just awesome. Speaking of 28psi, nice boost profile bryan, VERY nice!
