509whp 35R X
Old Apr 13, 2012 | 01:13 PM
akauf's Avatar
Originally Posted by JohnBradley
It is not a twin scroll. The reason is the biggest housing is the 1.06 T4 and I dont think that is a good match for how well the 4B11 breathes. Stock cams dont affect spool adversely, no.
Yeah boost hit 27 peak and then tapered down to 26 out the top. The 23.7 you saw is lag in the dyno recording the MAP sensor input relative to rpm.
You want the power further to the right? I presume you mean to the left?
The 1.15 t4 is now listed on fp's website. Are they not available quite yet?
Old Apr 13, 2012 | 03:00 PM
hotstix's Avatar
11.7:1 @ redline is considered rich?
Old Apr 13, 2012 | 03:14 PM
sstevojr's Avatar
Peak boost from 5-7k appears to be 10.5-11. Once boost tapers off, it's safer to lean out due to lower cylinder pressures.
That thread they made on EvoX was very informative, certainly threw a curve ball at some long established 'theories'
Old Apr 13, 2012 | 06:57 PM
EvoG8r's Avatar
Lot's of power but too laggy. I had a 35R on an STI and I don't miss it when compared to my 9 with HKS GTII.
Old Apr 14, 2012 | 06:49 AM
MOREPSiTEHBETT4's Avatar
^not a good comparison for many reasons.
Nice tune, that's a nice flat torque. 500whp on 92!!
Old Apr 14, 2012 | 07:07 AM
Kizzao's Avatar
Stock block andn internals? :O
Old Apr 15, 2012 | 09:02 AM
JohnBradley's Avatar
Stock block and internals. The 11.7 isnt exactly rich but where it is the EGT wont come into play as fast as if the whole pull was my normal drag race 12.0 or 12.3:1 pull. 4B11s run so much hotter its not a good idea to go crazy lean on the tune.
Old Apr 15, 2012 | 01:21 PM
hail2thetheif's Avatar
Pretty impressive!
Old Apr 15, 2012 | 04:49 PM
akauf's Avatar
I'm buying a turbo very soon. Do you think a hta86 in a 1.15 is a good choice fora high power street car? Anything else in that flow range that might be better?
Old Apr 15, 2012 | 05:42 PM
Mike Nguyen's Avatar
Nice numbers
JohnBradley
Apr 17, 2016 10:15 PM
JohnBradley
Evo X Dyno Results
13
Oct 27, 2013 07:37 PM
tscompusa
Jun 20, 2013 01:11 PM
JohnBradley
May 5, 2013 04:42 PM
evodave
25
Jan 12, 2005 06:32 PM
