MAP EF2.5 tuned by Cobb Tuning - Plano
Old Nov 5, 2014 | 08:52 PM
  #181
WitchDrDesigns's Avatar
Originally Posted by mkm492
Love my EF2. No noticeable lag. 449HP/381TQ (Spraying Meth/water) I didn’t go with the EF2.5 because the minimal benefits didn’t justify the loss in spool for me. I read that many MHI users like their turbos, but looking at there dyno sheets, the low end isn’t there like with the EF2. I think its the best for a stock bottom end/DD.
Did you get any runs on pump gas? I am looking towards the EF2 on my stock bottom but I only have 91 to sometimes 93 available where I am at and am curious to your numbers without the meth? Thanks
Old Nov 23, 2014 | 11:01 AM
  #182
ChrisWantsBoost's Avatar
Kracka, since this thread has popped back up: How have your EFs held through the years? There's been a bit on controversy lately over the EF turbos failing much sooner than they should.
Old Nov 29, 2014 | 10:26 AM
  #183
Hallj0806's Avatar
yeah any updates?
Old Dec 1, 2014 | 06:44 AM
  #184
Kracka's Avatar
No issues to speak of! MAP made a ton of changes/revisions since the original EF-series turbochargers debuted, all in the name of reliability and durability. I'd put their turbos second to none, people just need to remember that aftermarket turbochargers will always have a higher failure rate than OEM since they're pushed much harder. I sold the car back in March with 70k miles on it and it treated me well. I always ran Mobil 1 Extended Performance 10W-30 with 5k change intervals and gave it a few seconds to cool down before shutting off the engine. I reused the factory oil line.
Old Dec 1, 2014 | 06:48 AM
  #185
Kracka's Avatar
Originally Posted by lithe
Sorry to bring this thread back, lots of good info though...
Has anyone posted a dyno of the new MHI turbo to compare to MAP's offerings?
I don't mean to support a competitor, just help people make an informed decision I guess.
For me the ef2 seems ideal, just want to do my homework and not regret getting a MHI.
From what I've seen locally, the MHI 18K makes the power of an EF2, but spools like the EF2.5. One locally needed cams to even hit 400+whp on 93-octane (my EF2 did that on stock cams...same dyno & tuner). Otherwise, our setups were very similar with full bolt-ons.
Blue = local MHI 18K w/Kelford-B cams
Red = my MAP EF2 (stock cams)
Green = my MAP EF2.5 (stock cams)
Now imagine if either of my setups had cams too
Old Jan 11, 2015 | 08:34 AM
  #186
10evoxgsr's Avatar
Originally Posted by Kracka
From what I've seen locally, the MHI 18K makes the power of an EF2, but spools like the EF2.5. One locally needed cams to even hit 400+whp on 93-octane (my EF2 did that on stock cams...same dyno & tuner). Otherwise, our setups were very similar with full bolt-ons. Blue = local MHI 18K w/Kelford-B cams Red = my MAP EF2 (stock cams) Green = my MAP EF2.5 (stock cams) Now imagine if either of my setups had cams too
What is really crazy is that your ef2 made only 16whp less than my red on a built motor including cams. Same Dyno
Old Jan 11, 2015 | 08:40 AM
  #187
10evoxgsr's Avatar
Looking back your Ef 2.5 made 8 more hp than my red and here are my mods:
Fp red ported
Turbosmart 22psi wastegate
Ported head
Milspec 64mm tb
Dw1300 injectors
Aem 320 e85 fuel pump
Invidia cat back exhaust
Ams downpipe
Ams test pipe
Ets intake
Ets licp/uicp
Map rev 2 intake manifold
Cosworth mx1 cams
Cosworth valve springs
Wiseco 1400hd pistons
Manley h beam rods
Depo 4in fmic
arp main studs
arp head studs
acl main bearings
acl rod bearings
Old Jan 12, 2015 | 08:10 AM
  #188
murlo26's Avatar
Fp red ported
Ported head
Milspec 64mm tb
Dw1300 injectors
Ams downpipe
Ams test pipe
Ets intake
Ets licp/uicp
Cosworth mx1 cams
Manley h beam rods
Depo 4in fmic
arp main studs
arp head studs
acl main bearings
acl rod bearings
When you say same dyno, do you mean Cobbs? If not ignore it, your car made more power.
Old Jan 12, 2015 | 08:16 AM
  #189
Kracka's Avatar
Same dyno, same tuner...he was local to me at the time. If you ever drive down I'll pay for your dyno runs just to prove you wrong and shut you up My cars have been on DB's DynoDynamics, MAP's DynoJet, Cobb's Mustang, plus other local Mustang dynos. What more proof do you need? Guess where Cobb's reads? Within 3% of the other local Mustang. The last dyno day down here someone actually did a pull at Cobb then drove to the dyno day...< 1% variance. Anyway, enough is enough, it got old years ago yet you continue to hate for no reason other than to bash a shop you for some unknown reason don't care for. Maybe because your car barely makes it out of the garage these past few years? Just a thought.
Old Jan 12, 2015 | 08:20 AM
  #190
murlo26's Avatar
Same dyno, same tuner...he's local to me. If you ever drive down I'll pay for your dyno runs just to prove you wrong and shut you up
His sig said FL, so I assumed it was a different dyno.
That is a long way to prove something I already know is true I will never be silenced! muhahahahaha.
I suppose I could strap it on Ron's Dyno, make 400 then go down there and make 450whp...but that is a lot of driving. Maybe this next fall or something it will be a good vacation or something. I don't want to go when its hot.
edit: And if his car made less power, something had to be off. I am not knocking your ef2 or 2.5 setup kracka, it was well setup but his mod list suggests he should've been making quite a bit more power, something there seems fishy.
Old Jan 12, 2015 | 08:26 AM
  #191
Kracka's Avatar
He was local at the time, but has since moved. I love how you know something as fact, yet have never been to the shop or even ridden in a car they have touched.
I encourage you to drive down anytime, and will be very interested in seeing the results because I know exactly how they'll end up
Old Jan 12, 2015 | 08:36 AM
  #192
murlo26's Avatar
I know the man who set them up who has been there as do you. And yes, I take his word over many others
Regardless, I don't really care much to squabble over dyno numbers anymore. one of the reasons I like my VD now, as I just tell everyone the numbers are potentially bogus up front then no arguments can be made. I enjoyed wasting time talking about numbers when i first joined the forums but its become tiresome and no one wins. It's a tool and the only true measurement is the same dyno same day. Otherwise its to be tossed out the window in my book.
Your setup was great and the fpred guy had a nice mod list as well, both cars are probably plenty fast and we can all enjoy fast evos.
Old Jan 12, 2015 | 08:39 AM
  #193
Kracka's Avatar
I love him as much as the next guy, but he had nothing to do with the dyno setup @ Plano
Agreed 100% on dynos being a tool that shouldn't be compared against anything but the same dyno.
Old Jan 13, 2015 | 10:54 PM
  #194
evoxisking's Avatar
Cobbs dyno reads like like an uncorrected dyno jet
Old Jan 14, 2015 | 05:09 AM
  #195
Kracka's Avatar
Incorrect. I had my IX on both MAP's Dynojet and Cobb's Mustang; not even close. I've also had my Corvette on Cobb's dyno and another local Dynojet...
