MAP EF2.5 tuned by Cobb Tuning - Plano
Old Jan 25, 2013 | 03:58 PM
  #151
ryguy2588's Avatar
Great numbers!
Old Jan 26, 2013 | 06:04 AM
  #152
PlanoEvo's Avatar
Great numbers! MAP and Cobb a solid combo!
Old Jan 28, 2013 | 06:05 AM
  #153
Kracka's Avatar
Originally Posted by momostallion
they make different sized turbos for different power levels and desired powerbands for a reason. you don't (or shouldn't rather) buy a bigger turbo to make your motor safer. you buy a turbo based on your desired power level within it's efficiency range.
just because you may have a stock turbo running at 27psi doesn't mean you HAVE to spool it's ***** off by 2999 rpm.
Agreed 100% on the first comment.
at the 2nd!
Old Jan 28, 2013 | 06:06 AM
  #154
Kracka's Avatar
Thanks Andrew!
Old Jan 28, 2013 | 08:34 PM
  #155
DocBoz's Avatar
hey kracka did plano have to mod the bracket on the cold side that mounts it to the block, to clear the 3" inlet on your setup? i had to notch mine
Old Jan 29, 2013 | 05:37 AM
  #156
Kracka's Avatar
No fitment issues with my 3" inlet as far as I'm aware, but I'll go to the garage and double-check.
Old Jan 29, 2013 | 08:29 PM
  #157
DocBoz's Avatar
so did you ever get a chance to take a pic or look at the bracket?
Old Jan 30, 2013 | 05:49 AM
  #158
Kracka's Avatar
My bracket fits perfectly.
Old Jan 30, 2013 | 06:04 AM
  #159
Adam Brunson's Avatar
2008 and 2009 have different brackets than 2010+.
Old Jan 30, 2013 | 10:13 AM
  #160
Myth21's Avatar
Yup
Old Jan 30, 2013 | 10:42 AM
  #161
acidtonic's Avatar
I'm still curious if you regret the slower spool of the 2.5 Kracka?
As someone who has had both the EF2 and EF2.5, I'd like to ask your opinion for a 380-400whp goal. Your earlier thread had me sold on the EF2 but now I'm wondering if the EF2.5 will be better to grow with?
As it stands I love the response of the stocker and might even keep that. I've seen a few guys running full boltons with larger intercoolers on the stock turbo without cams making close to 380-400whp. But that is still a really hot setup compared to the cooler air from an EF2 right? What about longevity? Would an EF2 be better at 400whp than an aggressive stocker? I'm thinking so..... but why not a 2.5 to grow? I need feedback!
Old Jan 30, 2013 | 11:34 AM
  #162
Kracka's Avatar
If you love the spool and response of the stock turbo, but are seeking 380-400, then the EF2 is the easy choice. The EF2 has awesome spool and response characteristics; on the street I doubt you even notice the slight amount of lag vs. stock to be honest.
Old Jan 31, 2013 | 07:41 PM
  #163
Martinezusn's Avatar
Haha nice write up brother we almost made the same exact power on almost the same setup. I have a lot room to go by taking it ez cuz it's my daily lol. Map does make some great stuff. Check out my page right above yours lol. AWDKNG
Old Jan 31, 2013 | 09:10 PM
  #164
Thatotherguy's Avatar
Would the ef2 be able to have a flat tq curve of 325tq to 7k rpm
Old Feb 1, 2013 | 02:54 AM
  #165
Gyroscope's Avatar
why are none of these twin scroll?
