FP Black VS BW EFR 7670
Update on FP black
So I recently just pulled my head to get it built because i had a pretty noticeable tick coming underneath the valve cover so i was sure i bent a valve but anyway before that happened i decided to do a dual map tune so i went ahead and did the tune and i was very happy with the numbers i got with the setup i had. I had FIC1100 Injectors, AERO 340lph, Turbo XS dual turbo back with Map Open Dump, ETS manifold, 4' ETS FMIC and all hard pipes, ETS intake and last but not least FP Black @27 PSI. Now with that setup there i made 501awhp and 357 TQ and my tuner said I ran out of pump and injector. So this is what i did i decided to completely change my fuel setup with FIC 2150 INJECTORS, Walbro 450 hardwired, built the head, ETS Open dump, Few engine bay parts powder/ceramic coated, Purchased some Engine bay eye candy. I will be running E85 only and i am so curious and anxious to see what kind of numbers i will put down now on the same dynojet. I have both my dyno Sheets for pump and E85 tunes from before which i will post pics later and then once the car is tuned ill post the new numbers.
R/TErnie
Jun 12, 2014 07:56 AM
