Homelink Mirror Installed
Old Jan 3, 2009 | 01:52 PM
c_reber's Avatar
Originally Posted by Nammy
Is there some trick that I am missing when removing the factory mirror? Mine doesn't seem to want to just simply slide off. I've applied what I feel is enough force to get it to slide up toward the head liner, and if I apply anymore it feels like I might rip off the mount on the windshield.
Mine required a bit of force, but I wouldn't pull too hard, you don't want to damage your windshield. There was no trick for mine. I just slid it up towards the headliner parallel to the windsheild (I hope that makes sense). GL
Old Jan 4, 2009 | 08:07 PM
Nammy's Avatar
I was able to get my factory mirror off. I had never tried to remove one before, and it took a lot more force than I would have expected. I found that slightly twisting it from side to side while pulling toward the head liner helped it pop off. After I got it off, I noticed that there is a small clip on the underside of the mirror that allows it to latch onto the windshield mount to prevent it from working its way off. I imagine that twisting from side to side helped release this clip to allow the mirror to slide off (it's definitely the little clip that holds the mirror on), but it would probably be a good idea to be gentle as twisting too hard could torque the mount off the glass. I don't know if it would be possible to used a precision screwdriver or something similar to release the clip gracefully. Perhaps there is a tool for this.
Anyway, thanks for the help reber!
Old Jan 6, 2009 | 01:46 PM
Evolved360's Avatar
Could you wire this to the overhead light located by the mirror?
Old Jan 6, 2009 | 06:50 PM
stokEd's Avatar
Better later than never...
Old Jan 6, 2009 | 07:35 PM
stokEd's Avatar
Also, granted this is for the Evo IX, but this might provide some general help for some:
https://www.evolutionm.net/forums/ev...ng-mirror.html
Old Jan 6, 2009 | 07:37 PM
stokEd's Avatar
Oops...
Old Jan 18, 2009 | 01:48 PM
Runaround's Avatar
I just ran the wires down the a pillar to the fuse box area. It was easy for me because the dealership I got the car from already had installed an aftermarket alarm that they try and get you to buy. But I didn't buy it thier alarm and so they "uninstalled" it. So power was already T-tapped and I just had to find and T-tap an ignition wire, and then ground it also obviously.
If you want pics of the wires I'll try and get some.
And yes, you can buy them anywhere like ebay. Very easy and effective mod.
Oh and you shouldn't need the wedge mount as long as you are careful taking off the old mirror.
Could you please post a pic of the wires that were tapped. I haven't been able to find any pics of a 12v switched wire I can tap for my radar install.
Old Jan 18, 2009 | 03:10 PM
Nammy's Avatar
Here are a few pictures of how I installed mine. I also hard wired my radar detector at the same time.
I used the add a fuse things to tap power from my fuse box. The top one has the constant power wire for the mirror and I used the power door lock fuse. On the bottom one, I twisted both the switched power wire from the mirror and the hot wire for my radar detector together and soldered them to the add a fuse wire, and I used the cigarette lighter fuse for my switched power.
This is a pretty bad picture, but what I am showing here is my ground location. I twisted both the ground wires for the mirror and the radar detector together and grounded them both to the bolt that you see here. It's the bolt that's behind the top-right corner of the fuse box access panel.
Here is a picture of the mirror and radar detector installed. Hope this helps.
Attached Thumbnails Homelink Mirror Installed-evomirror1.jpg   Homelink Mirror Installed-evomirror2.jpg   Homelink Mirror Installed-evomirror3.jpg
Old Jan 18, 2009 | 06:19 PM
NyRsNy's Avatar
wow this was the one thing i missed from my old car lol
Im buying one right now! Nice find :-)
Old Jan 19, 2009 | 08:40 AM
scruffydog's Avatar
anyone know of one that also comes with a compass too?
Old Jan 19, 2009 | 12:03 PM
NyRsNy's Avatar
Yep click here
Old Jan 19, 2009 | 02:21 PM
qu evox's Avatar
this is awesome i am so sick of reaching inot my centoer console to hit the garage opener.
Old Jan 25, 2009 | 05:10 PM
EvoG8r's Avatar
That setup looks oem. I am going this route too.
Edit; if I wire up this mirror, can I hardwire my radar detector off the same wire with out overload it?
Old Jan 25, 2009 | 06:51 PM
goofygrin's Avatar
depends on which wire you pull the 12v from and how much juice your radar and this mirror takes. Most take very few amps so you *should* be ok. I'll likely be doing the same thing when I get the funds.
Old Jan 28, 2009 | 03:44 PM
mrMTB's Avatar
Same here. I also found a place that makes an AL bracket that connects to the rear mirror arm for mounting your V1. Gotta order this first, though, to measure the arm and order the right part.
