Rockford Fosgate front speakers to aftermarket amp?
How to connect RF front speakers to an aftermarket amp? AFAIK they are amplified separately by the stock amp. Has anyone done this, could you please share the experience?
The front speakers are two component. Under the stock setup tweeters and woofers are each connected to the amp, so there are four channels coming out just for the front and two others are for the rear.
The new amp 'expects' you to connect the front componets through a crossover, so there are only two outputs for the two front channels.
My question is how do you connect effectively four stock speakers to the two front outputs of the new amp?
The problem with replacing just the amp is that the stock amp is doing what is normally done by the head unint - sound processing. The stock HU is supplying only stereo signal and the amp is distributing it to all the speakers and the sub and does the related controls. So if you put and aftermarket amp you won't be able to control the sound processing features of the stock stereo.
akride907
Jan 9, 2016 03:29 AM
ddlopresti
Feb 23, 2015 01:17 PM
alexgaspari
Lancer How Tos / Installations
Apr 16, 2014 08:42 AM
bardia1985
Jul 4, 2012 09:05 PM
toyotabike
29
Oct 13, 2010 10:04 AM
