Can I keep factory Bluetooth on my 2010?
Old Feb 28, 2010 | 09:06 PM
Stevo-9's Avatar
I have a 2010 evo x with the SSS package. I want to change the head unit out to something with a real iPod control, but I use the steering wheel mounted controls alot. My question is can I keep Bluetooth if head unit is changed or at least have new head units Bluetooth controled by the steering wheel controls? Any info is appreciated!
Old Mar 1, 2010 | 06:27 AM
evolv's Avatar
While I haven't verified this myself, it seems as long as your new head unit has bluetooth/hands-free all you'll need is the additional module to allow use of your steering wheel controls (including the hands-free controls).
If the new unit does not have bluetooth/hands-free you're sotl.
Old Mar 7, 2010 | 03:19 PM
Stevo-9's Avatar
I thought I read that the bluetooth system is independent from the stereo. Meaning if you have a aftermarket head unit without bluetooth you can still use the factory bluetooth. Anybody know for sure?
Old Mar 7, 2010 | 05:11 PM
mrMTB's Avatar
The bluetooth is independent of the stereo. Since you have the SSS kit, are you planning on using the MITO-02 and keep using the built in amplifier? If you do this you will be able to continue using the factory BT, but I think you might end up having issues with the steering wheel controls if you want to use them with the new head unit.
When we were installing mine, and before I figured out we had to unhook the BT module, we would hit one of the stereo control buttons on the wheel (track up, I think), and it would key off something in the BT module when the PAC was hooked up... I think your best bet would be to find a head unit with BT integration, and use it all from there, disconnecting the BT module wiring harness.
If you choose to try to use the factory BT with a different head unit and the steering wheel interface, please do let us know how it works out, and if you have to jump through any hoops to make it work.
Old Mar 14, 2010 | 10:05 PM
Stuff's Avatar
I know this is late, but I just wanted to add something real quick...
I have the factory bluetooth as well as a pioneer d3. When you get a phone call, it looks like it cuts the power to the head unit. When it restarts, you have to clear that stupid warning screen. I'll probably upgrade soon, when I do, I'm going to add the radio bluetooth...
It's not a huge deal, but I just wanted to let you guys know.
Old Mar 24, 2010 | 05:41 PM
zerocooll21's Avatar
I just put a clarion head unit in and the factory blue tooth will not work. I have blue tooth on the head unit so it works through that but those button on the steering wheel do not work. I have a pac switch for the radio controls and that works but the blue tooth does not. I do believe the radio and blue tooth are two different systems, I can still see it as a option on my phone.
Has anyone figured this out?
Old May 13, 2010 | 08:54 PM
cpunlamd's Avatar
1. If you don't have the factory Rockford Fosgate system, you'll be able to retain the factory blue tooth.
2. If you have the RF system, you will need to use the Metra Mito-2 harness that WILL NOT allow you to retain the factory blue tooth. It may work for a short while, but your after market head unit will start to malfunction.
Old May 14, 2010 | 07:18 AM
Originally Posted by cpunlamd
1. If you don't have the factory Rockford Fosgate system, you'll be able to retain the factory blue tooth .
How so?? I have it working on my head unit but the steering wheel controls do not work anymore.
The Mito-2 is only for connecting a aftermarket stereo to a car with sss, it has nothing to do with the blue tooth.
Old May 16, 2010 | 06:04 AM
laxplayer14's Avatar
interesting. im curious to know too, i wanna put my kenwood ddx514 and i wanna know what i need to do to hook it up to still be able to use the factory bluetooth
Old May 17, 2010 | 07:58 PM
If your kenwood has blue tooth capabilities you will still be able to use the blue tooth through the cars speakers but it will only run through the head unit. The steering wheel controls as far as I know will not work. It sucks but I wouldn't wait, who knows if there will ever be a solution. If the controls for the steering wheel buttons tie into some part inside the factor head unit then chances are there wont be a solution. Just my 2 cents.
Old Jun 1, 2010 | 05:55 PM
rgomer's Avatar
Not meaning to beat a dead horse, but just for clarification, using the RF headunit will keep your bluetooth in tact. Does that include those installing the mitsu NAV system?
Old Jun 2, 2010 | 08:25 AM
If you're installing all factory pieces you will be good. Its the aftermarket radios that will require a separate module for the steering wheel audio controls and kill the blue tooth steering wheel controls.
Charlienofun
58
Mar 10, 2023 03:33 PM
Motordyne
Mar 10, 2016 10:08 PM
Severin
Mar 9, 2016 06:15 AM
kilroywzhere
Sep 16, 2015 08:50 PM
MFO Jester
Jun 22, 2008 12:15 PM
