Replacing the stock RF stereo
Web.... i have been reading around and saw mention of something called an LOC. Have you heard of this and can you shed any more light on it? It seems to be something that intercepts the signal from the head unit and seperates the channels and then connects to the amp with the RCA cables.
http://www.installer.com/item/displa...php?it=C2A-CHY
anbd then there is this...
http://www.installer.com/item/displa...php?it=MITO-02
Either way, I think I'd still be willing to lose fading. Nobody ever sits in the back anyway, lol.
This one looks interesting:
http://www.caraudio.com/forum/wiring...iring-loc.html
I honestly haven't heard of them before, time to do some research.
Great job putting all this together. I am about to take the plunge and do the amp (1st stage), then speakers (2nd stage), then sub and possibly another amp for it, and I have been reading those three other threads over and over. Now I have a one stop place for all my questions as I go through.
I have a question about the sub. Do you think there is any way to add an amp for the mid/high and leave the sub wiring alone? Maybe splitting the line in(s) off to another amp and leave them connected to the original amp? Reason I ask is because the car has enough clear bass for my music tastes now, and I would like to leave it until I get around to upgrading the sub.
I dont know if you can continue to use your RF amp to power your sub seperately from a new amp powering your other speakers. Since its CAN BUS driven and does all kinds of alternative tuning... it may not work.
However, the stock sub is pretty decent. As long as you don't overpower it, you'll be ok running it with any aftermarket amp.
Once I was done with that modification, I discovered that the box was STILL not quite deep enough. Somewhere I read it was 6.5", but in reality it's about 5.7-5.8" the W3 mounting depth is 5.93". So, with no other alternative, I decided to build a spacer ring with 3/4" MDF. Quick like:
Nice install man. I have a question. How does the 10W3v3 sound? I mean can you hear and feel it at volume? I have a 10W6v2 and it hits for sure but the heavily enclosed trunk really deadens it out. It just seems like a 10W3v3 in the OEM enclosure wouldn't be too much different then the stock sub. But then again I ditched the stock amp and its volume control too so maybe it sounds alright with a decent amp.
hi to every body and specially to webman!!!
very compliments for the job you made!! i have only one question!!
-i need to know if i have a 4 ohm sub what wires i must connect???
-i want to knwo if one of the others wires that you don't know one is the turn on signal wire for operating the aftermarket amp???if not how i can operate it remote??? or how i can do??
please answer me as soon as possible because i have the car in pieces!!!
LOC units pretty much receive the Power IC amplified signal from the outputs on the normal harness pins and remove the amplification for amplifier use. Preferably, you use aftermarket headunits with RCA outputs built-in for clean pre-amp signal to your amplifiers. Using headunits without these RCA's require you to use LOC units to achieve the same effect. Some amplifiers accept direct signal (a few Clarion models in my own experience) and these connections on these amplifiers do the same thing as the LOC.
Really, your best option would be to still do that and get a pair of bass-blockers (or the correct caps that do the same thing) to block only the sound to the tweeters, then pair the tweeters with the door speakers on the amp.
