Reverse Light Wire
Old Aug 19, 2010 | 04:45 PM
aduke05's Avatar
Reverse Light Wire
I am installing a backup camera with an aftermarket nav system. Which wire behind he dash is controlled by the reverse light switch? I don't want to run a wire from the reverse lights if I can help it.
P.S. I searched but did not find what I was looking for.
Old Aug 22, 2010 | 04:20 PM
aduke05's Avatar
Anybody? This is the only wire I haven't figured out yet.
Old Aug 22, 2010 | 11:53 PM
salukidude's Avatar
At one time I had a picture but I can't find it now. I installed my reverse camera a couple of years ago and never could find the wire under the dash at the time. I ended up following the white wire from the reverse lights to the back seat. Take out the back seat and you will find a thicker (maybe 14-16 gauge) solid white wire in a cluster of wires on the left (drivers) side. There are two looms of wires, but only one of has a thick and solid white wire. That's where I tapped in and it works good
Old Aug 23, 2010 | 04:30 AM
jackal5555's Avatar
I just tapped the reverse light wire as it was coming from the trunk lid into the rear deck. Took all but 3 mins.
Old Aug 23, 2010 | 03:49 PM
aduke05's Avatar
Thanks. I might just run a wire from the reverse bulb. I am running some wires from the trunk anyway.
Old Aug 25, 2010 | 08:26 PM
jackal5555's Avatar
Where did you mount your camera? I mounted mine right about the license plate. I'd like to move it up to the stock location in the middle of the truck, but its kind of an eye sore there and I don't want to drill into the trunk lid.
Old Aug 26, 2010 | 08:34 AM
aduke05's Avatar
I am going to mount it to the license plate. I don't like the stock location much.
Old Jan 27, 2020 | 08:19 AM
jeremy_montoya's Avatar
There's an easy to access wire that gets +12v behind the dash that was on a taped back plug. My Eve did not have the RF Nav unit, so I am figuring this does connect to that unit. That was my guess with that plug so I got out the DMM and probed each terminal on this plug until I found the wire that has 12v + when switching into reverse. It's the white wire with silver dots on my 2013 GSR. I connected this to the reverse wire on my Kenwood and I can now enable Reverse interrupt.
Old Apr 26, 2020 | 03:08 AM
snwtoy's Avatar
Thanks Jeremy!
Sorry for bumping an old thread, but this saved me running a whole other wire from the trunk.
2011 Evo X Manual Trans.
Old Apr 26, 2020 | 08:59 AM
97 GSX 97's Avatar
The easiest method I’ve found in previous cars was taping the power wire to the reverse light in the trunk. That way you don’t have to run a wire all the way to the front of the car too.
Old Apr 26, 2020 | 10:31 PM
snwtoy's Avatar
Yes, power for the camera from the reverse light, signal wire for the stereo from the white wire in the plug behind the stereo, as pictured above. That leaves just the single video cable to run to the stereo.
Veronica
Mitsubishi TC-SST Discussion
Aug 9, 2015 02:09 PM
JoeyM3
Dec 26, 2010 03:35 PM
Lourance
Feb 3, 2010 01:26 PM
CasperGSR99
Aug 12, 2007 08:22 PM
