Custom sub box behind seat?
Old Nov 6, 2010 | 03:19 PM
joe636's Avatar
Was able to take some pictures of the battery mount in its almost complete stage:
I need to mark and drill the mounting holes, and add one small piece of steel in the bottom plate to be able to use one more mounting bolt. This will use 3 out of the stock 5 mounting bolts.
Old Nov 6, 2010 | 09:47 PM
Modusoperandi's Avatar
Bravo!
You, good Sir, certainly have more, um, energy than I do. Not to mention your excess of Get up and go. Also, moxie.
Stop it. You're making me look bad.
Old Dec 3, 2010 | 10:09 PM
joe636's Avatar
Sorry for the slow update, but the girlfriend gave birth to a 20'' long boy, Daxtyn Carter Daniel Sauve
Anyways, the aluminum washer fluid jug came back, holds more fluid than stock, but should of done it differently. Should of made it lower, plus I didnt notice the little curve in the oem plastic piece that sits below the carpet in the trunk... so now it is being pushed out by the jug. I bought an universal pump, tubed it in, might try and see what the stock jug looks like again
I cut the bottom of the plastic deck piece a bit:
Also my new stereo bezel came in last week sometime, already pulled the one vent out of it and cut it up
I had two gauges in the old dsm I had years ago located in the center vent, so far its not much work to get them to fit in there. Just waiting on glue to dry on it for now, then I will be doing some more filling/sanding tomorrow. I want to get this done before the sub because its kind of more important and more useful. I didnt like the steering column mounts (blocks part of the instrument cluster), I dont like pillar mounts (too many things for passing drivers to look at), and the mounts under the HVAC controls are too low and too far away from the field of view.
Atleast the garage is warm for tomorrow
Old Dec 13, 2010 | 09:44 AM
joe636's Avatar
Still more work to do yet Too busy haha
Old Dec 13, 2010 | 09:01 PM
joe636's Avatar
Old Dec 14, 2010 | 06:10 AM
slebo3213's Avatar
Originally Posted by joe636
That looks great. What are you using for paint? Assuming you're just going to spray the whole piece? No concerns about using the heat in the car and having it blast right into the back of your gauges?
Old Dec 14, 2010 | 06:27 AM
oftheheavens's Avatar
that looks really cool, love to see it finished.
Old Dec 14, 2010 | 07:48 AM
total0wnage's Avatar
Wow i havent seen anything like this before, cant wait to see finished pics.
Steve?
Oct 29, 2015 07:39 PM
lncrphish
28
May 30, 2010 02:31 AM
grizly3610
10
Jan 4, 2010 05:21 PM
proverb
Lancer How Tos / Installations
Sep 24, 2007 11:38 AM
nothere
Mar 20, 2006 07:25 AM
