Prosport boost gauge help
Old Oct 13, 2013 | 11:38 AM
Schulzevo's Avatar
Hey guy just trying to install my boost gauge and wideband. I extended the wires like the how to said and hooked everything up and the gauge goes thru the beeping and flashing but then keeps flashing and never shuts off. The beeping stop but all the gauge does is flash and it stays at 0. Any suggestions?
Old Oct 30, 2013 | 12:12 AM
ikt's Avatar
ikt
check the wiring for your pressure sensor and make sure you don't have a signal line mixed up with a voltage line
Old Oct 30, 2013 | 12:23 AM
4G63_EVO's Avatar
check your pressure sensor, sounds like the problem
Old Oct 30, 2013 | 01:06 PM
Ountz's Avatar
Make sure the harness from the boost sensor is plugged in the back of the gauge all the way. I just had this issue and turned out to be the simple fix I just mentioned.
mrmiller
Mar 14, 2016 11:16 AM
bluetin
May 23, 2013 11:58 AM
ahr4156
Jul 7, 2012 08:43 AM
rcboosted
Feb 8, 2012 08:30 AM
SillySpheres
Sep 3, 2004 07:47 PM
