Does the 2014 Evo touchscreen radio support back up camera?
Old May 18, 2015 | 04:54 AM
  #166
dav30's Avatar
Hi
No it is the same plug but mine has already wire in it! Can you help with thanks. It is the same as post
Old May 19, 2015 | 09:00 AM
  #167
dcevox's Avatar
Wait you drive a lancer not an evo correct?
The plug you are looking for should have a red wire with white stripe in one of the corner, find that and take a picture of it.
Old May 22, 2015 | 09:54 AM
  #168
JakeSoberman's Avatar
Does anyone have any good recommendations for a back up camera? The wing really messes with depth perception!
Old May 22, 2015 | 11:26 PM
  #169
spyderx's Avatar
I just ordered this Dual camera dash cam w/ real time monitor. I plan to to use the rear cam live feed as my backup cam. It powers up and down w/ the car ignition power supply and can set default to display rear cam view constantly... And, you can use it for dash cam video capture too!
I plan to mount the monitor anchored to windshield right above the rear view mirror... If too bright for night then I'll move it down to lower center console.
http://www.spytecinc.com/k1s-1080p-d...amera-gps.html
Old May 23, 2015 | 11:29 AM
  #170
kwmark's Avatar
does anyone get the radio time reset problem after remove and put back the radio plugs ?
Old May 24, 2015 | 02:27 AM
  #171
dav30's Avatar
Hi
Yes driving a lancer i have the 3wires!
Old May 24, 2015 | 02:29 AM
  #172
dav30's Avatar
Hi
Yes driving a lancer i have the 3wires! With others more
Old May 24, 2015 | 05:12 AM
  #173
Symple's Avatar
Yes, ur basically taking power outta the radio so u have to reset the time again. That only happens when u unplug the main power plug.
Old May 24, 2015 | 06:48 PM
  #174
wilkes.1768's Avatar
Originally Posted by giumela
Just found the answer to my question. On page 72 of the Display Auto manual it states that rear view camera can be installed ..Time to get one off Ebay
Awesome find right there
Old Jul 2, 2015 | 09:25 AM
  #175
elocinX671's Avatar
I installed a Echomaster Vm-150 in my 2015 Evo X MR with non-nav touch screen. Just had to add the two pins like everyone else and it worked right on the first try, thanks to this thread!
Old Jul 2, 2015 | 12:37 PM
  #176
Lightsaber's Avatar
Originally Posted by Psybin
Here is a better photo. It's the top two with the red arrows. I'm not sure when he'll get back to me.
You'll have to trial and error to figure out which one goes where, but it shouldn't be hard to narrow down between the two.
Sorry I don't have all the answers as far as wiring it up, like I said my friend is the one who figured out what went where and actually knows how to wire things in.
I can push packages on SCCM but can't wire a backup camera lol.
Oh as a warning when he was first trying to figure out the pin out he did blow a fuse for the radio, one of the fuses under the dash. So if you are poking around and your radio display wont come on, check the fuses, I think it was one of those little 10 amps.
This is the pin out from my original posting he gave me
On 8 pin grey plug...
Pin 1 is power output
Pin 2 reverse sensor wire
Pin 3 is video signal ground (negative)
Pin 4 - n/a
Pin 5 is ground
Pin 6 - n/a
Pin 7 below is video signal (positive)
This info is just great! Psybin you are such a genius!!
Old Jul 13, 2015 | 07:13 PM
  #177
gotyaw?'s Avatar
Originally Posted by Lightsaber
For anyone looking for backup cameras, here is a list of major options:
http://rear-view-cameras-review.toptenreviews.com/
I'm personally leaning towards the Kenwoods one.
nice! ty
Old Jul 28, 2015 | 07:19 AM
  #178
BigT's Avatar
Will this one work?
http://www.ebay.com/itm/CCD-Color-Car-Rear-View-Reverse-Back-Up-Camera-for-Mitsubishi-Lancer-Evolution-/361184837881?pt=LH_DefaultDomain_0&hash=item54184b40f9
Old Jul 28, 2015 | 12:31 PM
  #179
EvoXtope's Avatar
Works great!
Camera smaller than a quarter
I liked this because you got options between mirror or normal, and with or w/o guidelines by just connecting a couple of wires.<br/>
Whats inside the box
Did a little variation from this guide. Instead of connecting the video rca directly to my head unit, I connected a female rca, so i can connect, disconnect or change my camera easier in the future.
Old Jul 29, 2015 | 01:08 PM
  #180
kosteniuks17's Avatar
Very nice! also smart of you to connect a female rca cable and run it to the back. I may have to do this. I'm planning to do this in the next few weeks/months. I'm just not big on pulling panels out etc. Is it pretty difficult getting to our headunits. I'm just nervous about breaking any plastic tabs, etc.
