I tapped into the wrong wire for power
I'm wondering if it may have caused damage. This is the passenger side. I read to tap into the big red wire, I thought I found it but I was mistaken. I had the battery disconnected when I did my solder. I am trying to power some gauges. Can anyone tell me what the red wire I originally tapped into is for?
Here is where I tapped:
This is the big fat red wire is where I should have tapped:
Agreed. Go with the fuse method, cleaner and potentially less headaches. The door lock fuse should have constant power and Cig. lighter fuse for switched ignition. Sample pic below to get an idea of what tapping the fuse is.
Source: http://rawevo.com/evo-x/how-to-guide...on-your-evo-x/
When I did my reverse camera I went into the fuse panel with an add a fuse:
How does the test light tool work? Can I test for hot wires without having to tap into them?
Where would I look in the service manual to find out exactly what the wire I spliced into originally was for. I'm trying to find out if what I did could have damaged anything.
Thanks.
Thanks.
I don't think you messed up anything. Its not like you're adding more power to the "big red wire" from the gauge. You're trying to get power from the big red wire so whether it an actual power or not you'll be fine. Just make sure you cover it back up nicely to prevent short circuit and do the fuse tap! A lot easier and safer!
koolzero
Evo X How Tos / Installations
10
Mar 15, 2014 12:55 PM
nogoEVO
59
Apr 26, 2011 06:29 PM
