Weird Problem with Driver's Side Taillight Bulb (Not Brake Light)
Old Sep 12, 2014 | 03:03 PM
alby988's Avatar
Question Weird Problem with Driver's Side Taillight Bulb (Not Brake Light)
Hey guys, I'm having a weird problem with the rear tail light. The light that comes on when we turn our lights on (not the brake light) doesn't go on once in a while (driver's side only).
Out of frustration, I did a light tap on the tail light that went out and it came back on. Ever since then, whenever I notice the light isn't on, I just tap the outside and it comes back on.
Does anyone have an idea of what may be wrong and what steps I should take to fix it?
I'm guessing it's not the bulb as the light comes back on when I tap it, is it something with the connection? And if so, what should I check for?
Thank you guys, really appreciate it!
Edit---
Changed the wire and viola works perfectly now
Old Sep 18, 2014 | 07:47 PM
.M.'s Avatar
.M.
Check the connection/wires like you said. Make sure nothing is loose. The bulb might not be making good contact. You can always change it if you're not sure. I'd start with that.
circuitEVO
Nov 2, 2016 12:55 PM
wowzers
Dec 13, 2014 01:14 AM
dailydriven09
Lancer Troubleshooting
10
Oct 21, 2014 07:35 PM
Joshs EVO
Jul 11, 2011 08:18 AM
azyan
Jan 7, 2004 04:33 PM
