Launch Control....MR question.
Old Feb 2, 2009 | 04:57 PM
  #46
OG Mogie's Avatar
Differences I've seen using Launch and not is about .3 - .5 off the times. So yep good time your rolling there.
I'm still stock and doing like 5.1's with Launch and about 5.4 or so without. Soon as summer is here, its mod-time.
Old Feb 3, 2009 | 02:52 AM
  #47
boostsaves's Avatar
I did a 5500rpm launch today no Hes.
Old Feb 3, 2009 | 10:45 AM
  #48
Q15H's Avatar
I recently ran two AP recorded performance runs (wish it would datalog at the same time it was recording performance times!) and found some interesting [wierd] results.
Both tests were in S-Sport mode using launch control. First test was a 0-60 performance test:
60' - 2.023s
330 --
0-60MPH - 4.919s
Second test was about five minutes later, and measuring 1/4 mile performance:
60' - 2.484s
330' - 6.065s
0-60MPH - 4.919s
1/8 mile - 9.027 @ 83.282 MPH
1000' - 11.571s
1/4 mike - 13.716 @ 105.657 MPH
Getting two exact 4.919s 0-60 MPH is extremely curious considering there's 0.46+ seconds diff in the 60' times.
Attached Thumbnails Launch Control....MR question.-img_0001.jpg   Launch Control....MR question.-img_0002.jpg   Launch Control....MR question.-img_0003.jpg
Old Feb 3, 2009 | 10:52 AM
  #49
LVSBB6's Avatar
I also noticed the consistency in AP performance runs, what kind of mods are you running?
60' - 2.023s
330 --
0-60MPH - 4.919s
60' - 2.484s
330' - 6.065s
0-60MPH - 4.919s
1000' - 11.571s
Old Feb 3, 2009 | 11:57 AM
  #50
Q15H's Avatar
Cobb AP Stage 1 91 ACN map with a cat-back exhaust.
Old Feb 4, 2009 | 09:44 AM
  #51
Japistani's Avatar
What kind of cat-back? I have an AEM intake and am running the Normal Stage 1 map, since I logged both the ACN and Normal maps and noted very similar knock retard values...
Old Feb 4, 2009 | 08:14 PM
  #52
Q15H's Avatar
I've run between the Stg 1 91 ACN and the Stg 1 93 maps. There's about ten HP difference peak between the two maps but I recorded the highest HP with the AEM and the Stg 1 91 acn map at 290. Curious although the 93 map was tested with stock intake on different day.
The exhaust is a bushr cat-back dual. Haven't run dyno with current config. Will get results with stock, stg 1 91 acn and then stg 2 91 acn same day. Maybe next week as I'm busy on the cooler project for now.
Old Aug 20, 2012 | 02:33 PM
  #53
Piotr Kurkowski's Avatar
Ok, I've got a question about SST Launch control
Does it always drops to 4k after launch ? I have a problem with this, is there any way to bypass that and keep revs going up instead of dropping from 5.5 to 4k ?
This video got me thinking
Also what is the best way to start with launch control and realse break before it reaches 5.5k ? It my case I did launch at 4-4.5 with that pause or rev drop 2-3 times but usually it automatically gets to 5.5k
Any suggestions ?
I have custom cat-back in my EVO and power increased to 350BHP and 450Nm
Old Feb 13, 2014 | 05:17 PM
  #54
IRISHEVOX's Avatar
hmmm i need to try and launch and then post results
Old Feb 14, 2014 | 01:02 PM
  #55
IRISHEVOX's Avatar
Well i followed all the steps ya'll said and i still got a problem any suggestions?
Old Feb 14, 2014 | 10:31 PM
  #56
torana's Avatar
you have to push the brake down firmly and foot straight down on gas, if you hesitate on the gas peddel or release the brake a bit it will do what happenend in the video.
i can even do it in normal or sports mode and without holding down traction for 3 secs for some reason.
once the stall is on you can rev it up and down like you have the clutch in then let it go at different revs under 5000
it revs up with no boost
Old Feb 15, 2014 | 09:43 AM
  #57
IRISHEVOX's Avatar
I will try again and see what happens
europaul
Mar 16, 2016 10:12 AM
BeyondLimitsEvo
Mitsubishi TC-SST Discussion
Aug 27, 2012 10:31 AM
BeyondLimitsEvo
Cobb AccessPORT
Jul 20, 2012 08:07 AM
GraphiteEvoX
19
Sep 12, 2011 05:45 AM
audiofan
Apr 3, 2011 05:36 PM
