Mivec advantage?
Old Oct 22, 2009 | 08:51 PM
  #76
fmax420's Avatar
Originally Posted by MR Turco
so is everyone using the same intake/exhaust map in both tables (#1 & #2)? I couldn't find any information on when the ECU uses one or two.
Not sure. Anyone?
Old Oct 22, 2009 | 08:56 PM
  #77
TTP Engineering's Avatar
From what I gather, the ECU uses #2 under normal operation. Many are making 1 and 2 the same.
Old Oct 22, 2009 | 09:23 PM
  #78
Clipse3GT's Avatar
Yes, it would be helpful on more information regarding how the EVO X MIVEC is setup and really what makes it tick.
It seems there is really very little knowledge floating around how to setup the 4 maps. I guess some more insight would be great. :-)
Old Oct 22, 2009 | 10:04 PM
  #79
xPRimNT's Avatar
I was under the impression that #1 was warmup MIVEC.
It would make sense.
Old Oct 23, 2009 | 12:03 AM
  #80
GST Motorsports's Avatar
#1 is run until 147f, then it interpolates with #2 until 170f then #2 runs 100%
- bryan
Old Oct 23, 2009 | 09:09 AM
  #81
Clipse3GT's Avatar
- bryan
Does that only apply to intake? or exhaust as well? both?
Thanks Bryan
Old Oct 23, 2009 | 09:42 AM
  #82
xPRimNT's Avatar
Both. I wasn't aware of the interpolation between 147 and 170, but that's good to know.
Old Oct 23, 2009 | 10:32 AM
  #83
Clipse3GT's Avatar
x2
Old Oct 23, 2009 | 04:38 PM
  #84
4G63DSM's Avatar
Variable valve timing is amazing isn't it!
Old Oct 23, 2009 | 04:40 PM
  #85
EVILBLOODBROTHA's Avatar
Thats some crazy stuff
Old Oct 23, 2009 | 09:16 PM
  #86
BigT's Avatar
Variable CAM Timing. Variable valve timing is on Hondas.
Old Oct 23, 2009 | 09:32 PM
  #87
UT_EvoX's Avatar
Ummm... it's variable valve timing still - the cam timing IS the valve timing. In fact, MIVEC stands for Mitsubishi Innovative Valve (timing) Electronic Control (system). Honda's i-VTEC includes variable valve lift as well, in addition to variable valve/cam timing.
Old Oct 25, 2009 | 06:40 PM
  #88
E6-X's Avatar
- bryan
based on what temp ? from air temp ? coolant ?
Old Oct 25, 2009 | 06:45 PM
  #89
blackdemon's Avatar
very impressive results. keep us posted
Old Oct 25, 2009 | 07:05 PM
  #90
Hiboost's Avatar
I'm quite sure it's coolant temp, your car will start adjusting LTFM as needed a few seconds after it hits 170F and that's considered full operating temp as far as the ECU is concerned. For the Mivec settings on my car I ended up making the #1 warmup maps just a less aggressive version of #2 full operating temp maps. Granted I avoid hammering on the car when it's warming up but it's good to know that in case I forget it should be tuned to accomodate it safely.
It likely won't make a ton of difference but lets say you disabled the timing retard during warmup or reduced it like I did to avoid hesitation, then run 25+ psi boost via an MBC, and then run full aggressive Mivec settings. If you make a habbit of going WOT right after the car is started up you will have a higher risk of breaking something or at least adding in some pre-mature wear to various parts.
