ECUFlash 1.41 released
Old Feb 18, 2009 | 11:20 AM
  #166
GST Motorsports's Avatar
Originally Posted by Guru
Those of you with big turbos. What load sites are you guys hitting? Are you running stock MAF housing? What values do you guys have for the boost settings. I'm running a red and it seems to run pretty close to stock peak load sites (220ish) at only 1 Bar or so. Is this correct?
At 14.7 psi it runs 220 load? The stock turbo hits that at 21-23psi.
Old Feb 18, 2009 | 01:40 PM
  #167
SiC's Avatar
SiC
Pure stock hits about 255 load at around 3500 RPM (23 psi). At 7000 RPM it drops to about 180 (12 psi).
Old Feb 18, 2009 | 06:38 PM
  #168
stokEd's Avatar
fun
Hey guys, I just started a thread so that we can consolidate all the PCMScan questions: https://www.evolutionm.net/forums/ev...an-thread.html
Old Feb 22, 2009 | 04:29 AM
  #169
taug6's Avatar
Originally Posted by gunzo
Send me the roms for the EDM .. and I'll generate the XMLs for you ..
For now .. it does open UK ROMs .. and I consider them EDM too ..
Gunzo,
tried to read my ecu (evo X FQ300 SST) with ecuflash and got this message:
[11:23:36.588] -- unlocking ECU --
[11:23:36.604] starting session...
[11:23:36.963] requesting seed...
[11:23:36.979] sending key...
[11:23:36.994] no key(s) worked - perhaps this ECU has been intentionally locked?
[11:23:36.994] interface close
[11:23:37.025] interface close
So I wonder how it can open the UK roms if all UK- ECU are locked (ecutek locked them if I am not mistaken)?
Old Feb 22, 2009 | 04:34 AM
  #170
SiC's Avatar
SiC
Originally Posted by taug6
Gunzo,
That's odd, we can read other EDM ROMs such as the FQ360 & RS....
Old Feb 22, 2009 | 06:21 AM
  #171
gunzo's Avatar
Gunzo,
Cool .. yours actually replied with NO KEYS WORKED !!
There's some issues with UK roms .. they are rendered unable to read or write using ECUFlash ..
On the bench .. the ECU responds the same to the flash ..
Sorry .. So far only FQ330 and FQ360 are the only roms we can read now ..
I have an idea why this is so .. but can't confirm it
Old Feb 22, 2009 | 02:13 PM
  #172
taug6's Avatar
Freezing cool mate Better known as no cool at all
You don't have to confirm it, just mention it
At the same thing that this hapenned, I got a warning about the AFS on the car's display
When you say the bench, do you mean with just a power supply and the OBDII connection ?
Does this message have to do with any locking that the initial Ecutek programmed ECU might have ?
Assumptions of what is happening, suggestions (how it can be solved ) are very welcome
Your feedback and your patience are greatly appreciated !
Old Feb 22, 2009 | 05:37 PM
  #173
awddyno's Avatar
How did you guys turn the P0420 code off for cat efficiency? For those people running a cat delete.
Old Feb 22, 2009 | 07:35 PM
  #174
SiC's Avatar
SiC
Disabling the rear O2 is not available in ECUFlash yet so people that have them use the O2 fix (anti-fouler or 90 degrees bend).
Old May 15, 2009 | 08:21 AM
  #175
taug6's Avatar
A few months have passed now... I wonder, any luck on that front ?
Old Aug 3, 2009 | 10:12 PM
  #176
ace33joe's Avatar
Gunzo,
My friend tried to read a JDM EVO X rom, and he got similar error (with AFS warning sign at the display too).
Any solution to this? He cannot even start his car.
[13:52:30.578] -- unlocking ECU --
[13:52:30.578] starting session...
[13:52:30.578] requesting seed...
[13:52:30.593] sending key...
[13:52:35.640] interface close
[13:52:35.656] interface close
Old Aug 4, 2009 | 01:57 AM
  #177
gunzo's Avatar
Ooh .. my favourite
goto ECU on the dropdown menu and select EXIT PROGRAMMING MODE ..
I'm going to say its probably not going to work .. because something else is wrong with his car ... just a guess though !!!fingers crossed for you !!
Old Aug 4, 2009 | 04:20 AM
  #178
ace33joe's Avatar
Ooh .. my favourite
I'm sorry, but are you talking about the ECU Flash? Do we have exit programming mode option at the ECU flash?
He got those message when he is trying to read the rom.
donour
Apr 1, 2010 03:39 AM
b0ostedEV08
May 16, 2007 12:34 PM
colby
Mar 10, 2007 01:23 PM
jcsbanks
Sep 30, 2006 09:16 AM
djmikeymike
Jul 17, 2006 08:32 AM
