ECUFlash 1.41 released
Old Jan 29, 2009 | 04:15 PM
dustin03's Avatar
Originally Posted by GST Motorsports
EcuFlash has never logged evos, any version. It is flashing software only.
Ok so Evoscan does not work for the X how do you plain on getting around this. I mean you would not want to tune a car not knowing if it is knocking or not. Anyone can flash a car but a good tunner will log it too.
Old Jan 29, 2009 | 04:44 PM
SiC's Avatar
SiC
For now, most use a generic OBD2 logger and compare the actual IGN timing to the target IGN timing in the maps. If the actual is lower than what is in the maps, more than likely it's caused by knocking. IGN timing should gradually climb, in most tunes at WOT, as the RPM rises. If you have fluctuation or dips in the IGN timing, it's more than likely knock.
Old Jan 29, 2009 | 05:05 PM
xbox4414's Avatar
Words of wisdom. Thanks for your help!
Old Jan 29, 2009 | 05:22 PM
MR Turco's Avatar
Can someone verify is you really need service pack 3? and do you need it just for the CAN stuff?
Old Jan 29, 2009 | 05:30 PM
dierr's Avatar
can't wait to see some results!
Old Jan 29, 2009 | 05:52 PM
gunzo's Avatar
Originally Posted by KOTT
It doesnt open roms of EDM cars (manual and sst)...
Send me the roms for the EDM .. and I'll generate the XMLs for you ..
For now .. it does open UK ROMs .. and I consider them EDM too ..
Old Jan 29, 2009 | 06:00 PM
KOTT's Avatar
pmed
Old Jan 29, 2009 | 06:14 PM
xbox4414's Avatar
I haven't flashed with the computer I am on now, but it's using SP1 and it installed fine and the program loads fine. I haven't opened a ROM or done a ECU read or write.
Old Jan 29, 2009 | 06:52 PM
PeteyTurbo's Avatar
great news!
Old Jan 29, 2009 | 07:20 PM
dustin03's Avatar
Is there still problems with cars going into limp mode and throwing check eng lights with this flash wear? Just what I heard
Old Jan 29, 2009 | 07:24 PM
saulbyu's Avatar
^ How much are we talking about for an e-tune? Can you e-tune to specific mods?
Old Jan 29, 2009 | 07:46 PM
chueu's Avatar
what generic odb2 logger would you be talking about//
Old Jan 29, 2009 | 07:50 PM
SiC's Avatar
SiC
Many of us use PCMScan
Old Jan 29, 2009 | 07:51 PM
Ph3n1x's Avatar
Does this one include Flash recovery in case the ECU gets bricked?
Old Jan 29, 2009 | 08:06 PM
SiC's Avatar
SiC
Yes
