ECUFlash 1.41 released
Old Feb 1, 2009 | 12:36 PM
  #61
burnings's Avatar
Quick Qns
Just a quick qns. Currently, I have AP with a tuned map installed. When I uses eculash and read from rom, does it read the tuned map or stock map?
If itz downloading the tuned map, does it means that I can reflash this map back to my car at a later time?
Old Feb 1, 2009 | 12:37 PM
  #62
xbox4414's Avatar
IDK, hook up OP2 and check I would really like to know if AP maps work with opensource but I'm pretty sure Cobb locks their stuff...
Old Feb 1, 2009 | 01:54 PM
  #63
Noize's Avatar
EvoM Administrator
Originally Posted by MR Turco
I think this thread should be cleaned up.
Originally Posted by honda-guy
i totally agree, this thread is about ECUFlash, not ECUFlash vs. X ,Y and Z.
if you're trying to promote ECUtek, then you're in the wrong place. people who look in this thread are DIY kinda people and have already made the decision to ECUFlash.
Originally Posted by Petey Turbo
+1 for turning this thread into an ECUtek world class promotion thread..
Originally Posted by BigmikeOC
I love the tags that are showing for this thread. Especially - "***** ecutek in thread".
Just glad someone beat me to it. I wonder if that will be the only alternative tuning solution to be whored here or if the usual suspect will show up as well?
Originally Posted by GST Motorsports
You said:
Then you say:
Are you done whoring out ecutek in a ecuflash thread yet?
Perhaps getting back on topic would be a good thing for the community...
I have to say it is quite funny to see the same exact thing happening yet again. EcuFlash comes out and you are yet again whaambulancing about it exactly like you did when EcuFlash came out for the 8/9. History repeats itself indeed...
You guys all cry foul and some of you reported posts, but Guru started this with the EcuTeK bashing.
I'll clean the thread, but you can't have it both ways. Leave EcuTeK out of the thread, and people won't rise to defend it.
For all parties, from here on out, please keep thread about Ecuflash.
Old Feb 1, 2009 | 01:58 PM
  #64
Noize's Avatar
EvoM Administrator
Originally Posted by xbox4414
Well yes a few things are off topic, but that is a ECUFlash issue we got to take into consideration. Some users may post tunes from vendors and post them here. There is no lock on ECUtek against the ECU from ECUFlash, it creates an issue of is it right to share these maps to the opensource community. And I believe EvoM forbids the sharing of vendor maps.
xbox4414 is right; it is an offense that will result in the offender being temporarily removed. Strike 2 is a permaban.
Here's everyone's free warning to not do it.
Last edited by Noize; Feb 1, 2009 at 04:56 PM. Reason: clarification, not a strike against the quoted poster, but a restate of the rules to everyone.
Old Feb 1, 2009 | 01:59 PM
  #65
Noize's Avatar
EvoM Administrator
Petey Turbo, knock off the antagonistic tags. Keep it up, and there will be infraction points for flaming.
Old Feb 1, 2009 | 02:19 PM
  #66
mrfred's Avatar
There's only the Cobb ROM in the ECU. The stock one is stored in the AP. Not sure if you'll be able to read it though. My guess is that they took steps to make the ROM unreadable except by the AP.
Old Feb 1, 2009 | 02:25 PM
  #67
SilverEvoX's Avatar
Yeah it's only readable by the AP now. Previously it was confiscateable I believe but the firmware updates now prevent this.
Does anyone have any good MIVEC maps for the X yet other than the JDM maps that have proved good gains? Thanks.
Old Feb 1, 2009 | 02:49 PM
  #68
DynoFlash's Avatar
The tuned map or installed map is what is read
Yes you can reinstall the same map in your car later
Old Feb 1, 2009 | 03:17 PM
  #69
cpoku's Avatar
So with this version which of the patches are obsolete and which can still be used? example we don't need to add the ECU Periphery because it is already present. How would i apply the jdm map patch and other mrfred or tehpra patches so it wont cross with others listed (maybe listed under another name)?
Old Feb 1, 2009 | 03:43 PM
  #70
mrfred's Avatar
I've worked out a new way to keep all the custom definitions in a separate file:
Check out this post: https://www.evolutionm.net/forums/ec...ml#post6476121
The Evo 8/9 xmls covered in that post are the same ones in the 1.41 release.
Old Feb 1, 2009 | 04:33 PM
  #71
cpoku's Avatar
Thx ill make the upgrade then
Old Feb 1, 2009 | 08:14 PM
  #72
nj1266's Avatar
Originally Posted by Manboy
I'm putting together a 'How-to' if anyone's interested (PM me). PCMScan isn't free though. Licenses run $99, but so far it seems worth it. Already used it to clear a DTC (P1235) this morning.
How fast is the pcmscan for logging? Is it as fast as Evoscan? Can we integrate the wideband with it like Evoscan?
Old Feb 1, 2009 | 08:30 PM
  #73
SupremeX's Avatar
1) Not as fast as evoscan.
2) Yes, supports wideband
Old Feb 1, 2009 | 08:43 PM
  #74
nj1266's Avatar
Does the software work with the Tactrix 2.0 cable w/o any other hardware? Do I need to buy any hardware with their software license to get the full version?
Thanks
  #75
SiC's Avatar
SiC
I don't know how to explain the speed but logging with 12 parameters in 4th gear on a dyno from 2000RPM to 7400RPM it logs every 50-80 RPM.
And yes, you can hook up an external wideband, I have my AEM connected to it.
