TephraMODs for the X
Old Oct 21, 2009 | 07:19 PM
  #76
lodifreefly's Avatar
Originally Posted by murlo26
I really doubt that will happen, I am pretty sure the SST logic is in another module, not the ECM.
edit: However I am guessing all the modules are on the CANbus and none are isolated, wouldn't be a reason to isolate them, so in theory it is possible, but could be outside the realm of the software (ECUflash).
Yup agreed. But if Im not mistaken the trick would be to find a routine that interfaced with the tcu somewhere and was aware of the shift mode. Then you could potentially leverage that. Impossible to say whether or not such a routine exists but it doesn't seem too unlikely given how tightly the two seem to be married.
Old Feb 4, 2010 | 08:10 AM
  #77
agron25's Avatar
News?
Old Feb 11, 2010 | 10:34 PM
  #78
superman37r1's Avatar
Updizzates?...
Old Feb 12, 2010 | 06:23 AM
  #79
Hiboost's Avatar
Good questions, what exactly are the technical hurdles to implement some of these features on the Evo X ECU?
Old Feb 12, 2010 | 02:34 PM
  #80
tephra's Avatar
Well I already have KnockCEL going, I should have altmaps going soon as well.
I am thinking about implementing a TPSCutonKnock as well..
Just been busy thats all
Old Feb 12, 2010 | 02:43 PM
  #81
joedr's Avatar
EvoM Moderator
Thumbs up RA Support!
That is very good news!
Hope that you have time for port the changes for us the RA members.
I think that it is time for a donation!
  #82
Mellon Racing's Avatar
a tps cut on knock would be very cool but may be dangerous if abrupt or unexpected don't you think?
Old Feb 12, 2010 | 02:45 PM
  #83
Golden's Avatar
Do you think there is any way to make changes to our center digital display? With the 2010 being in color, I have a few changes I'd make.
And, it would be very interesting to add stuff from the ECU on there, like a screen that shows boost, knock sum, speed, tps, and more.
Old Feb 12, 2010 | 02:46 PM
  #84
Golden's Avatar
It could be a percent cut, or a taper off. An instant cut to 75% throttle wouldn't affect too much, but should stop the knock and save the engine.
Old Feb 12, 2010 | 03:00 PM
  #85
migs647's Avatar
You. Are. A. God. /bows
Old Feb 12, 2010 | 03:03 PM
  #86
onboost's Avatar
i have been thinking about this since iv had my car (2 years)
Old Feb 12, 2010 | 05:05 PM
  #87
tephra's Avatar
yeah that would be cool.
BUT i think it will require reprogramming of the cluster..
Old Feb 12, 2010 | 05:38 PM
  #88
Hiboost's Avatar
Exactly what I was thinking, somewhere around 40% would still allow 20-25 psi so you could test the effects of cutting to certain TPS levels to see what works best. Heck even if you had the boost cut to WG pressure during major knock that would work similar as well but maybe not quickly enough.
Old Feb 12, 2010 | 05:49 PM
  #89
tephra's Avatar
yeah I did the WGCut on CT9A, but throttle is a MUCH better way of doing it.
realistically you have about 0.5 second reaction time from when hearing the knock to taking your foot off the gas... this could be cut dramatically by using the ECU instead of the human
Old Feb 13, 2010 | 07:29 AM
  #90
Clipse3GT's Avatar
Very cool Tephra keep up the good work! Pretty awesome with the knockcel.
