TephraMODs for the X
Old Mar 6, 2010 | 06:17 PM
  #136
xPRimNT's Avatar
Seriously, you're amazing.
I love this stuff, I just don't have any ability to do the actual "hacking" things.
If you need testing though, you know where to find me! Guess I'll need to pry off the stupid anti tamper shield on the ECU. I can't believe they did that, stupid Canada.
Old Mar 6, 2010 | 06:30 PM
  #137
tephra's Avatar
does the anti tamper cover the plugs as well?
if it doesn't you can just leave it.
Old Mar 6, 2010 | 06:37 PM
  #138
xPRimNT's Avatar
Yeah, that is the only thing it covers. It's mean.
Bolted on with shear bolts too, takes some dremelling to actually get off.
Old Mar 6, 2010 | 06:42 PM
  #139
tephra's Avatar
really..?
thats a bit dumb, what if you need to disconnect the ECU for some reason?
Old Mar 6, 2010 | 07:00 PM
  #140
xPRimNT's Avatar
Originally Posted by tephra
really..?
Then you get your dremel
We dealt with that on a local X, I needed to bench the ECU. Discovered that the first step of removing the ECU was acually the hardest part
Old Mar 7, 2010 | 03:14 AM
  #141
IrvineXGSR's Avatar
just to get this straight before i get too excited for this ...
meth failsafe is a go for the USDM X?? i'm dying to run meth!
Old Mar 7, 2010 | 05:08 AM
  #142
tephra's Avatar
correcto..
I am still working out which path I will go for USDM (IC wiring, or using the fuel tank temp OR pressure input)
I prefer 1 solution for ALL regions, but whatever is easiest
Old Mar 7, 2010 | 01:21 PM
  #143
derekste's Avatar
hi tephra. just throwing it out there that I'd love to test the first X tephra-mod. (knock-cel is all I could test... don't need map switching just yet).
fostytou(now my roommate) is probably picking up an X in the next day or 3... we'll have two X's under one roof (-: both will probably be going E85 this summer as well...
Old Mar 7, 2010 | 03:05 PM
  #144
tonyboy's Avatar
^^ can't wait for the alt map for the meth people thanks tephra!
Old Mar 7, 2010 | 03:58 PM
  #145
silthos's Avatar
well there will be two (maybe 3) activation methods for map switching
1) cruise control holding down to switch maps - good for E85, or different fuels
2) voltage input into ECU - good for meth failsafe switching
3) might use TPS as well - depending on whether people want it (not really needed since CC will do the job)
so with #2, its working now with the fuel tank pressure input... BUT this isn't very easy on USDM.
So on USDM I might use the IC setup - which means you will need a 5v relay to switch +12v to the IC input...
most meth failsafes are +5v, the IC will expect +12v...
wont be too complicated
Will this be available for the 09-10 ralliarts (USDM)?
Old Mar 7, 2010 | 03:59 PM
  #146
tephra's Avatar
possibly - if there is enough interest
Old Mar 7, 2010 | 04:01 PM
  #147
silthos's Avatar
im willing to help fund this for the ralliart community!!!
Old Mar 7, 2010 | 07:26 PM
  #148
fostytou's Avatar
EvoM Community Team
Testing and funding
Old Mar 7, 2010 | 10:10 PM
  #149
tephra's Avatar
congratz dude
Old Mar 15, 2010 | 06:25 PM
  #150
tephra's Avatar
quick q:
how useful will people find an "Alt Cranking Enrichment Map"?
if people will use it for E85 I want to implement it now rather than later :P
