EvoScan for Evo X Beta Parameter CAN-ID's? Log attached
Old May 6, 2009 | 09:52 PM
  #76
rogue's Avatar
Ahh, I guess editing from within EVOSCAN corrupts the XML file somehow. If I start with a fresh Data.xml and make the edits manually, then it saves and works fine. I bet I missed that small fact somewhere in this thread.
Old May 6, 2009 | 09:57 PM
  #77
SiC's Avatar
SiC
Originally Posted by rogue
Interesting problem for me. Once I make changes to my data.xml file, my item to log screen, where I can selected parameters, no longer shows up regardless of what "ECU" I select less the EFI choice.
I even went as far as to reload evoscan and had the same issue. Basically a blank screen.
Yeah, that's the same for everyone. If you want to edit the xml, you have to edit it in wordpad or something. Also, if you want to restore your previous data, grab the data.xml from the 2.6 beta update and put it into the install folder.
Old May 7, 2009 | 12:49 PM
  #78
rogue's Avatar
I posted a new thread regarding using evoscan and determining why a P1235.
https://www.evolutionm.net/forums/ev...cel-p1235.html
Daimon
Old May 8, 2009 | 01:09 AM
  #79
Deannn's Avatar
Ive been playing around with Evoscan and my datalogs miss patches ? do i need to change some settings or something. I also changed around Knock to 11-1, few other things that i got of this topic but my logs dont look right, showing 18* knock retard.
Could this be real? :S i have 3" catback and HKS panel filter on 98RON.
Acer Laptop: T7300 @ 2ghz with 2gig ram, XP with SP3.
Any help would be greatly appreciated.
Dean
Attached Thumbnails EvoScan for Evo X Beta Parameter CAN-ID's?  Log attached-evoscan.jpg
File Type: zip
Old May 8, 2009 | 01:21 AM
  #80
WarmAndSCSI's Avatar
Dean
I don't see 18 anywhere... I see 8, which is OK. Try to minimize this value. It is indeed the correct knock sum/count. I've gotten my own tune down to a max of 1-2 counts.
Old May 8, 2009 | 01:49 AM
  #81
Deannn's Avatar
ah duno where i saw 18, but theres few that say
LogID LogEntrySeconds TPS RPM KnockRetard
36 5/8/2009 55:22.8 2.65926 14.90 843.75 14 0 13
See the 13 one, is that 13 counts ?
Old May 8, 2009 | 05:52 AM
  #82
SiC's Avatar
SiC
Dean
I don't understand your log..... were you just free reving the motor? I don't see any areas that you actually went WOT.
Old May 8, 2009 | 10:39 AM
  #83
Deannn's Avatar
Nope was not free reving.
LogID 975 till 1125 i think.
Ill try get better ones tomorrow.
Old May 8, 2009 | 11:09 PM
  #84
mrfred's Avatar
Originally Posted by WarmAndSCSI
EvoScan is telling me 64/sec so I guess 8/sec if I'm logging 8 items? That's about what I see in my logs. 6-8 per second. Not great, but it works I guess.
I'm getting about the same logging rate on an Evo 10 I got to play with today. It seems that EvoScan is way slower than the 180 values/sec that Hamish said he was getting. Kind of a bummer compared to my Evo 9 where I get 160 values/sec.
In looking at the WOT logs, I'd say that there is lots of room to improve the logging parameters (finding correct logging parameters and correct scalings).
Old May 9, 2009 | 01:02 AM
  #85
tephra's Avatar
yeah its a bit buggy..
hopefully he will release a new version with faster + reliable logs
Old May 10, 2009 | 12:18 AM
  #86
GST Motorsports's Avatar
I get about 5-6 samples in a full 3rd gear pull. Almost 1 sample for every 1000 rpm.
Old May 10, 2009 | 01:27 AM
  #87
tephra's Avatar
and whats wrong with that :P hehe
mine is better than that...
Old May 10, 2009 | 08:24 AM
  #88
nj1266's Avatar
I am getting ~11 samples per second. I do not know why my Evoscan is behaving and yours is not!!
Old May 10, 2009 | 10:41 PM
  #89
SiC's Avatar
SiC
Originally Posted by GST Motorsports
Yea the adapters can be a pita sometimes. It's all app centric it seems like
My Keyspan works perfect with logging in Evoscan / Mitsulogger / Zeitronix
However It won't let me connect to the Zeitronix warning box to program it.
The adapter that Zeitronix sells however does.
I got the Keyspan adapter and it worked!!!!!
Thanks Bryan!
Old May 10, 2009 | 10:47 PM
  #90
Thanks Bryan!
No problem, always glad to help.
