Cobb AP - How accurate is built-in dyno?
Old Oct 30, 2010 | 07:32 PM
PhantomBlack's Avatar
Dyno ap accuracy
I just went out and did another dyno run with my ap, this time in 3rd gear from 2000-7000 rpms. I only hit 6750rpms.(i dont know if that affects the results). It was 3 degrees celcius. My last run above it was about 10 celcius with 2nd gear pull. My car definately hits harder in the cold temps, but the results I just got are CRAZY. Max hp = 422.51 @ 4477 rpms, max tq = 500.45 @ 4285 rpms! Something ain't right!!
Old Nov 1, 2010 | 10:26 PM
kozmic27's Avatar
The built in dyno on the AP is not even a little bit accurate
Old Nov 2, 2010 | 08:27 AM
Golden's Avatar
Hollywood made his accurate. His post on the subject is on the other forum in the dyno section.
In theory, it should work the same as virtual dyno's do.
Old Nov 2, 2010 | 08:59 AM
evoxgsr2010's Avatar
I got 420hp/450tq on on a car with an intake, turbo back, and OTS Stg 2 tune. It's not even in the ballpark. I actually made 328whp/349wtq on Cobb Plano's Dyno on the exact same setup. And it was COOLER on the dyno day haha.
Old Nov 2, 2010 | 01:43 PM
1fastevo00's Avatar
Wow, those are some big variances.
Old Nov 2, 2010 | 02:02 PM
kozmic27's Avatar
I don't trust the virtual dyno's either, but the one that Barnhill has put together seems better than most.
The same day I dyno'd my car on a J-Trans mustang at 500hp/400 tq, The dyno in my AP said I had some idiotic amount of power over 650 with a similarily stupid torque number. This was on a perfectly flat road, with a known weight from the scales at an NHRA sanctioned track.
I messed around with it until it got close, but in doing so I had to tell it that my car weighed about as much as a civic. It may have improved since then, but I'll have to wait until I tune a car with an AP again to find out.
Old Nov 2, 2010 | 05:09 PM
GiLizILL's Avatar
my dyno is actually accurate, and so is the 1/4 mile
Old Nov 2, 2010 | 07:37 PM
ice1874193's Avatar
is cobb bhp? If stock is around 220whp and 291bhp then its about 25% difference. so your 420 bhp comes out to about 315whp (ap) which isn't that far off....who knows
jake33
Jul 29, 2015 08:14 AM
evo10fanatic33
Dec 14, 2014 04:58 AM
evo10fanatic33
Cobb AccessPORT
Nov 19, 2014 10:06 AM
EvoXman23
Oct 22, 2013 12:19 PM
babaz7
Oct 1, 2011 11:08 PM
