Stock evo x mr using dataloglab...
Looks like the Evo X had a better Cd than the previous generations due to design, still didn't see exact specs though.
http://www.mitsubishi-motors.com/cor...008/20e_08.pdf
I've been using 0.34 and it seems to do a good job. I've set frontal area to 22.9, based off measurements someone took on a different forum.
My curb weight is set to 3594 (with SSS packaged) based off someone weighing their car.
Smoothing factor of 2 seems to be fair.
I'll just attach my car definition file
Rename from EVO X GSR 5-Speed.car.txt to EVO X GSR 5-Speed.car.
Also attaching my DDL template to read evoscan logs. enjoy!
Rename from EVO X GSR 5-Speed.car.txt to EVO X GSR 5-Speed.car.Also attaching my DDL template to read evoscan logs. enjoy!
well i bought my works air filter and doing some Dll the filter is a great mod for this car,also you can feel the difference but here it is according to DLL i did both runs the same day and same hour maybe 10min in between the runs its what took me to change the filter.
here is the graph.
it gained 10whp and 10ftlb of torque wow for just a filter!
here is the graph.
here is the graph.
here is the graph.
In car and driver, they calculate FA this way:
Width X Height X 0.91=FA. That gives the Evo X a 26.27 sqft FA.
jrsimon27
32
Jan 27, 2007 08:20 PM
jrsimon27
11
Dec 12, 2006 04:47 AM
