Low-Load High Knock Explained
Old Jul 23, 2009 | 10:53 AM
blk-majik's Avatar
This might be a bit of a noob question for this thread, but it is related.... and I can't find a good answer
How is load % calculated in the X?
Old Aug 13, 2009 | 07:39 PM
sdfontanini's Avatar
weird phenomenon.
Evo VIII on e85 getting high knock counts, with evoscan in low rpms 2800-3200 rpms....
Above 3200 I can rip on the car without a count... below and gradually rises.
Tried changing the timing, both down then up. Nothing happened, same response, Leaned it out a bit, and nothing happened. back to timing and nothing.
I'm just stumped... Only other issue I hear is my power steering pump, which wines like a dying bird... thought that could be setting it off but I won't know till I replace it.
Got M2's, 16g, and fullrace header.
Old Aug 14, 2009 | 07:06 AM
coevolve's Avatar
Originally Posted by tephra
see my "stock GSR log" thread.
not using an AP - but should give you some insight..
Can you provide a link to that thread? I was unable to locate it through the search tool
thanks man
-B
Old Aug 17, 2009 | 07:42 AM
LaXGSR's Avatar
Originally Posted by fast_bloke
So this isnt anything to worry about then?
I've seen similar behavior (although usually under 10 knock sum) at low rpm/load. Sometimes I can repeat it a few times in a row, and other times not so easily. It seems to do it about half the time. Did you figure anything out? I tried reducing timing by 1-2 degrees but it didn't help. The stock timing map in that low rpm/load region jumps a lot. I tried to smooth it out, but maybe it needs to be made even smoother? Not sure why mitsu did what they did in that region for timing, so I didn't want to mess with it too much.
Old Aug 17, 2009 | 10:42 AM
I'm thinking of just turning down my knock sensor sensitivity
Old Aug 18, 2009 | 07:54 AM
coevolve's Avatar
If I understand correctly, the knock sensor is doing it's job in filtering sound that logically equates to "knock". Under light load, while the knock detection is viable the actual event is moot b/c it lacks the ability to cause any damage. However, under heavy load you do not want the knock sensors ability to detect such conditions minimized...
Old Aug 28, 2009 | 06:15 AM
veta's Avatar
I just can say, you cant get knock at 1700-2000rpm on zero Boost and 15-17degree of timing (talking about stock evo engines) . I have 30-35degree of timing at this point with no knock.
Last time i have run the evo X i have noticed something realy unusual. It was doing noises like it has ALS activated, but it was nearly stock X-SST. Car has missfired and poped into the exhaust, like ALS. I can imagine that could cause some noise on knock sensor.
Old Aug 28, 2009 | 06:36 AM
uranium9v's Avatar
My mazda does the same thing, logging with AP I can see part throttle knock at3.6k rpm ONLY when the car is still warming up. After the first 20miles it goes away. Looking at my map in ATR, 3.6k rpm is where theres a load increase.
Old Aug 28, 2009 | 10:36 PM
still having knocking issues, can't put a finger on it. gonna make me so.e det cans here tomorrow and see if its real knock or just something else. again it only happens around 3k rpms
tunermt
AEM EMS
24
Dec 13, 2025 01:26 AM
PIE-R
Dec 21, 2019 08:14 PM
PPM
Apr 2, 2015 09:35 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
Seijuro
Mar 20, 2010 11:53 AM
