Resetting codes
Old Aug 25, 2009 | 09:24 PM
contagius's Avatar
Resetting codes
If I reset a code that I dont know what it is and it doesn't come back does that mean everything is OK? Sorry this sounds so stupid.
Old Aug 26, 2009 | 03:28 AM
robh's Avatar
Do you remember what the code was? I could look it up for you.
Did you get any other codes when you got this one?
chances are if it did not return right away it would not be a hard fault but it may have been a code that requires the car to be driven x amount of times or one that would require certain things to be met to run the test like an evap monitor if this is the case then the code will return when it tries to run the test again
my advise would be if you get the code again write down the number
Old Aug 26, 2009 | 06:22 AM
tephra's Avatar
unless it comes back or unless you remember the code I wouldn't worry about it..
Veronica
May 31, 2013 11:51 AM
Crester
May 26, 2011 05:51 AM
manilaboy
Lancer Troubleshooting
May 17, 2009 04:00 PM
ernald711
Oct 14, 2008 04:28 PM
jonjon123
15
Oct 10, 2008 07:50 PM
