help!!!! thermostat location?
Old Aug 29, 2009 | 11:33 AM
markmacoy's Avatar
where can i find the thermostat coz i want to change it, and which one is the best in the market today?
tanx in advance
Old Aug 29, 2009 | 11:36 AM
e_leo's Avatar
Mine has 76.5C from factory.Ralliart has the same opening temp.
Ooops,wrong place for this thread.
Old Aug 29, 2009 | 11:50 AM
markmacoy's Avatar
where can i find the thermostat in the engine bay?
Old Aug 29, 2009 | 12:05 PM
cush87's Avatar
They are usually where the upper radiator hose connects to the engine. I haven't changed one on an Evo X yet. That's where they are on every other car I have changed them.
Old Aug 29, 2009 | 12:23 PM
robh's Avatar
follow your upper radiator hose the thermostat is in the block right above the bellhouseing drivers side
Old Aug 29, 2009 | 12:51 PM
kozmic27's Avatar
Why do you want to change the thermostat? There is nothing wrong with the temperature the factory thermostat is set to. If you are having a problem with the engine not cooling, it is not going to be the thermostats fault unless it has failed.
Old Aug 29, 2009 | 02:01 PM
Hiboost's Avatar
I have to agree, the factory opens at 176* F or so which is perfect operating temp for power and still relatively cool. Assuming your cooling system has the capacity it should be able to hold it at that temperature assuming proper airflow while the engine is running and flowing coolant through the water pump. Opening the thermostat for flow earlier will initially run the car cooler but then heat up past that after the cooling capacity of the radiator is overun just as before.
If your car takes longer to reach normal temps it will run in your warmup maps for many functions limiting Mivec settings, boost, and timing. You are best off actually increasing the cooling capacity with a larger radiator, water wetter additive, and proper airflow through the radiator via fans and ducting. You want to quickly reach proper operating temps and then hold there consistantly.
Old Aug 29, 2009 | 02:17 PM
pensport's Avatar
I just installed the mishimoto racing thermostat but car is under construction so I cant give any reviews.
Old Aug 30, 2009 | 01:34 PM
markmacoy's Avatar
tanx guys
mindoftw
Feb 20, 2016 06:09 PM
KillaItalian904
Jan 9, 2013 01:40 PM
evascst
Aug 11, 2011 07:48 AM
REV.olution
Jun 14, 2011 07:54 AM
EVOKRAZY8
Oct 11, 2010 10:20 AM
