Difference between '08 and '10 GSR stock tune (ROMs 52680020 and 55570005)
Old Nov 9, 2009 | 06:57 AM
therocket's Avatar
Question Difference between '08 and '10 GSR stock tune (ROMs 52680020 and 55570005)
Hi guys,
I've already read many threads about this subject, but I found different opinions so I need your help.
The main question is: is the '10 GSR stock tune (ROM 55570005) exactly same as '08 GSR latest stock tune (ROM 52680020)? [And so, also same as ’09 GSR tune (ROM 54060007)?]
Someone says that between ’08 and ’10 model ROM is different but tune is exactly the same, someone else says that the only difference is lean spool enabled (from ’09; and they also suggest to disable it when tuning), someone else says that also other things are different and in fact even power measured on dyno is higher (also max torque is rated at different rpm: 4400 rpm for ’08 and 4000 for ‘10).
Can we do a clarification about this?
Thanks guys!
Stefano
Old Nov 16, 2009 | 12:23 PM
FTY Motorsports's Avatar
i dynoed a bone stock 2010 evo x GSR on road race engineering's dyno pack and it did about 295whp BONE stock.
Old Nov 16, 2009 | 12:36 PM
190hpkilla's Avatar
WOW
Any others with similar HP?
Old Nov 16, 2009 | 03:15 PM
GST Motorsports's Avatar
A 291 fly hp rated car put down 295whp? lol
I just checked all tables. Boost / fueling / timing / mivec tables all 100% the same as 2008 Evo 10.
- bryan
Old Nov 16, 2009 | 03:17 PM
total0wnage's Avatar
ya that doesnt sound right lol.
Old Nov 16, 2009 | 03:49 PM
Clipse3GT's Avatar
- bryan
Maybe a FQ360...
Old Nov 17, 2009 | 01:50 AM
therocket's Avatar
- bryan
I also found the same thing: all tables are exactly the same, I cannot find any difference. But I have not the experience that you and others guys here have, so this is the reason because I opened this thread.
In any case, it's strange that the max torque is rated at different rpm between '08 and '10 models.
Old Nov 23, 2009 | 02:50 PM
Mike W's Avatar
It was a bone stock car with your base flash tune, no? Dont be feeding the dyno numbers warz trolls :-P
MIke W
Old Nov 23, 2009 | 03:25 PM
GetterDragun's Avatar
I think people said the torque peak is different because there is a function called "Lean Boost" that is enabled on the 2010 ECUs.
Old Nov 23, 2009 | 03:58 PM
SiC's Avatar
SiC
You mean Lean Spool and yes it's enabled in the 2010 models.
Old Mar 7, 2010 | 02:54 PM
MIke W
no with the base flash it was like 305whp i went completely stock and it did the 295. idk it was so long ago.
tephra
Aug 29, 2021 04:47 AM
Gunther45
Apr 11, 2012 10:10 AM
RngrYogi
Jul 10, 2011 09:32 PM
Raptor58559
Mar 24, 2011 06:13 AM
03whitegsr
Oct 17, 2009 10:20 PM
