Gauges needed for a turbo upgrade...
Old Dec 6, 2009 | 11:16 AM
alktrio06's Avatar
So I want to upgrade to the FP Green, I was wondering what gauges I needed for such an upgrade. Obviously I would need the boost and the wideband, but with the MR, would I need anything else?
Old Dec 6, 2009 | 11:36 AM
flyguycfi's Avatar
Boost, Wideband A/F, and EGT at the least I would say. That's everything that goes with the Zietronix ZT-2.
Anything beyond those 3 would just be personal preference really. Maybe some others will have some input.
FWIW I've seen some prosport guages recently that looked pretty good if you want to go on a budget.
Old Dec 6, 2009 | 11:44 AM
SilverEvoX's Avatar
I'd say oil pressure instead of EGT if you are going to be running a wideband afr anyway because they both tell you practically the same thing. Go with a dependable wideband and gauges in general not cheapy ones, when you're monitoring important engine data the last thing you want is your gauge to be off with whatever its reading.
Old Dec 6, 2009 | 12:00 PM
alktrio06's Avatar
I was just going to comment,that I thought the wideband and the egt measure the same. I was going to go AEM all the way. I will consider oil pressure, I was also thinking trans temp as well, especially with the MR trans
Spencer2362
Sep 21, 2015 05:09 PM
code4evo
Pacific Northwest
Jan 1, 2013 10:41 AM
erggy
Oct 4, 2008 06:19 AM
hytek369
10
Sep 10, 2008 04:22 PM
Inprogress
Jan 29, 2008 10:06 AM
