NEED HELP with ECUflash
Old Jan 8, 2010 | 09:23 AM
EVOXTIMES's Avatar
I'm trying to save some patches to my rommetadata file 52680020.
The following path is what I'm trying to save.
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
after doing the necessary cutting and pasting, I try to save and this message appears....
"Cannot create the C:\programfiles\openecu\ecuflash\rommetadata\mitsu bishi\evo\52680020.xml file. Make sure the path and file name are correct."
no matter what i try i cannot get it to save!!
I know its something simple but I need some help!!
any suggestions?
Thanks in advance!!!
Old Jan 8, 2010 | 11:38 AM
Clipse3GT's Avatar
You are putting it in the wrong file... nub cake.
It is supposed to go into 52680015 NOT 52680020.
Because file xxxxxx15 and above use 52680015 as the main file read.
It is also supposed to go into the MISC category.
Old Jan 8, 2010 | 04:06 PM
EVOXTIMES's Avatar
I tried that already.
Same message.....
Old Jan 8, 2010 | 04:07 PM
EVOXTIMES's Avatar
Same message.....
plus it shouldnt matter it's a superceeded file.
i have two different laptops that this is happening on. My computer at work works fine!
This is driving me crazy!!
Old Jan 8, 2010 | 07:17 PM
EVOXTIMES's Avatar
Ive been following your thread on EvoXforums and I'm stuck on step 8...with the same message.
Old Jan 9, 2010 | 09:44 PM
EVOXTIMES's Avatar
issue has been resolved through properties.
I also put in a patch for the rear o2 disable. and installed a wideband today, but still have the "service engine soon " light. any ideas?
Old Jan 10, 2010 | 06:02 AM
Clipse3GT's Avatar
The patch does not work correctly IIRC...
Old Jan 14, 2010 | 11:36 PM
EVOXTIMES's Avatar
is there anything i can do to get the light to go away.
if not I'm just going to install a test pipe and weld another bung for the wideband.
Old Jan 15, 2010 | 01:04 AM
tephra's Avatar
what DTC code do u get with rear02 disabled?
also your initial problem was probably Vista related...
Old Jan 15, 2010 | 02:57 AM
EVOXTIMES's Avatar
the code was P0037 ......really vista related...hmmmm
I have another laptop with XP I can try. Thanks....
Another problem Ive been having is that I cannot read my ecu with ecuflash. Only test write and write. Any ideas why this may be?
Thanks again Tephra!
