really bad knock all of a sudden
Old Feb 8, 2010 | 12:23 PM
  #166
BigT's Avatar
Well I would hope that Mitsubishi engineers thought about all this when they designed the mivec system.
Old Feb 8, 2010 | 01:52 PM
  #167
SiC's Avatar
SiC
No doubt that they did, these engines do not have an EGR system but with exhaust mivec, they can retard the exhaust to allow exhaust gases to enter the combustion chamber. By doing this, it will allow the engine to run cooler and prevent excessive NOx.
Japanese emissions testing is done while the vehicle is driven steady at 60km/h. If you look at the JDM exhaust mivec map, the cruise load area has high exhaust mivec retarding. I am almost certain that this mivec map was designed specifically for emissions testing. In the higher RPM range, they also use some exhaust mivec retarding and this was probably done for protection in the high RPM/load areas.
Old Feb 8, 2010 | 03:06 PM
  #168
Bugermass's Avatar
Originally Posted by hollywood_X
I think your missing what I am getting at and there are some flaws in your reasoning there. With aggressive MIVEC you can push fuel out of the cylinders and into the turbine housing, which is typically running temperatures of 1700*F. The flash point of gasoline is -40*F with an (auto ignition) temperature of 475*F. Since you just swept it through the motor with your clean incoming air it has perfect levels for ignition.
So effectively your motor is burning off the air fuel mixture that is measured but only part of it is in the chamber, and whats left in there is lean.
I was thinking about this today while working on some stuff, and while your theory on this phenominon is sound, in order for this to occur you'd have to have at least a 1:1 pressure differential across the head or better. Basically your backpressure would have to be low enough that the boost and fuel could actually make its way OUT the exhaust. I can garuntee you these motors/turbos in stock form have loads of backpressure, not only from a common sence observation but even from the fact that they move the exhuast cam to achieve EGR like results.
This means even when not in boost the exhaust pressure is great enough to revert back into the cylinder with only a few degree of exhaust retard, imagine how much more pressure there is when you have an exhaust expansion ratio relative to 20PSI of boost pressure and higher RPMs on these tiny turbine housings.. I seriously doubt you are pushing raw fuel into the turbo... I feel pretty sure that the extra knock is from cylinder contamination with those hot spent gasses causing a higher potential for knock..
In your example, you'd have 1700deg exhaust gasses reverting back into the cylinder, that seems to be a more likely cause for increased knock with aggressive mivec mapping.
I'm not saying this IS the anser, but I feel its much more likely with this particular setup. I will still test this theory though, both on a simular to stockish evo and on a really free flowing setup..
Old Feb 8, 2010 | 03:48 PM
  #169
Clipse3GT's Avatar
I don't notice there is more knock with aggressive MIVEC. I notice that the AFR's lean out more... But even if they lean out lets say to 13's there is no knock... just a lean AFR and a higher PSI (i.e. 26 PSI, 13 AFR, 0 knock)... then the AFR's jump to the correct set AFR. In my case about 11.8-12 AFR on the wideband.
Old Feb 8, 2010 | 04:35 PM
  #170
tephra's Avatar
yeah... which is the worrying bit for me...
Old Feb 8, 2010 | 06:30 PM
  #171
Bugermass's Avatar
Originally Posted by tephra
quick question, can MIVEC in itself cause knock?
assuming you had a correct AFR, could having too much MIVEC cause knock?
it was kinda in anser to this question and somewhat the other guys statement about fuel going out the exhaust. sorry I usually type in a rush or on my phone and my explinations get sorta jumbled.. haha yeah I re read it all and I kinda mixed up stuff, but the theory still applies in general..
Old Feb 8, 2010 | 07:02 PM
  #172
tephra's Avatar
if anyone (mrfred) has got any ideas on how to log MIVEC let me know...
otherwise i'll have my head deep in asm
Old Feb 8, 2010 | 07:06 PM
  #173
SiC's Avatar
SiC
+1
So guess what I thought was logging actual mivec seems to be target mivec, my logs are always inline with my mapping.
Old Feb 8, 2010 | 07:07 PM
  #174
tephra's Avatar
what are you logging? ill do a quick check
Old Feb 8, 2010 | 07:10 PM
  #175
SiC's Avatar
SiC
Intake VVT 23809434
Exhaust VVT 23809452
Both use (x-4096)*-0.01953
This is on a JDM 2008 so it should be the same with yours.
Old Feb 8, 2010 | 07:34 PM
  #176
tephra's Avatar
Originally Posted by SiC
Intake VVT 23809434
Your intake is just a lookup from the maps (after coolant temp interpolation)
Your exhaust is ONLY the lookup from #2 table.. so under coldstart it will be wrong.
But yes - both are targets, rather than actual.
Old Feb 8, 2010 | 08:04 PM
  #177
SiC's Avatar
SiC
Makes sense
Now we need to know how to log the actual
Old Feb 8, 2010 | 08:05 PM
  #178
tephra's Avatar
yep... pity its fricking complicated
Old Feb 8, 2010 | 08:15 PM
  #179
mrfred's Avatar
Just finishing up something for my real job. I'll take a look right now if you like.
Old Feb 8, 2010 | 08:18 PM
  #180
tephra's Avatar
lol.
i have found the code that throws the DTC (P0365) when exhaust cam activity is not moving, but after that I am a bit lost!
