FIC 1100's Experience?
Old Apr 28, 2010 | 07:24 AM
  #91
tephra's Avatar
nah - 300 is about when the ECU goes into open loop so the STFT will be 0% - which in tern means the trims wont update...
Old Apr 28, 2010 | 07:49 AM
  #92
tsitalon1's Avatar
Thanks for the validation!
Old Apr 28, 2010 | 08:57 AM
  #93
Golden's Avatar
Originally Posted by tsitalon1
You still golden, Golden?
Just checking on ya......
Yes, I am only 1 tick different from your values.
Code:
Scale = 943 (91 octane) and 665 (E-85)
4.69     5.90
7.04     4.87
9.38     2.88
11.73    1.94
14.08    1.46
16.42    1.15
18.77    1.03
This is an hour drive on the second tank of E-85
Old Apr 28, 2010 | 09:00 AM
  #94
Golden's Avatar
Oh, and thanks again for doing all the work for me.
I loaded your values in and she started right up as if I changed nothing. And same with E-85. I just took the scale * .70 and ran it completely out of gas. Then I filled her up with E-85 and she started like a champ. This was way too easy.
Old Apr 28, 2010 | 09:33 AM
  #95
tsitalon1's Avatar
Code:
4.69     5.90
7.04     4.87
9.38     2.88
11.73    1.94
14.08    1.46
16.42    1.15
18.77    1.03
I'm curious, your scaling of 943 is for 93 octane vs my scaling of 914...
Also the latencies seem a bit different as well...
Mine are:
Code:
4.69     5.904
7.04     4.872
9.38     2.880
11.73    1.968
14.08    1.488
16.42    1.176
18.77    1.056
Wonder what would happen it I tried yours?
I loaded your values in and she started right up as if I changed nothing. And same with E-85. I just took the scale * .70 and ran it completely out of gas. Then I filled her up with E-85 and she started like a champ. This was way too easy. ]
No problem, glad I can contribute to the community!
Old Apr 28, 2010 | 11:57 AM
  #96
Golden's Avatar
Yeah, I bumped the Scaling up to 1 size bigger and the Latencies to 1 size lower.
My gas is 91 octane with 0% Ethanol. It shouldn't be any different than 93 octane. I put the Ethanol rating in there as some places have 93 octane with 10% Ethanol. The Ethanol can change your scaling.
Also, I just figured out the other day that I can log while starting the car. So this winter I will be logging during very cold starts to see if I can help it start easier on E-85. I did notice that the voltage dropped to 9 volts while cranking, so I'll probably have to mess with the latencies in that area.
Old Apr 28, 2010 | 12:09 PM
  #97
tsitalon1's Avatar
Thanks for the additional info, I may play with my configuration a bit...I do have 10% ethanol at my pumps, which I see as a dbl edge sword...
I'll report back if/when I play with my settings.
Old Apr 28, 2010 | 01:16 PM
  #98
GST Motorsports's Avatar
IPW adder table if you don't already know.
My personal Evo 8 running E85 the last two years has started up first crank every time down to 12F after sitting all night in snow (about the coldest I've been in so far here in California).
Proper tweaking of the IPW adder table goes a long way to proper E85 cold starting.
- Bryan
Old Apr 28, 2010 | 01:17 PM
  #99
fostytou's Avatar
EvoM Community Team
Do you have the XML for the cranking IPW tables?
Old Apr 28, 2010 | 01:22 PM
  #100
evo10base.xml
<scaling name="TimeInjCranking" units="ms" toexpr="x*0.005" frexpr="x/0.005" format="%.1f" min="0" max="500" inc="1" storagetype="uint16" endian="big"/>
<table name="Cranking Enrichment IPW Adder (Main)" category="Fuel" type="2D" scaling="TimeInjCranking">
<table name="Coolant Temperature" type="Y Axis" elements="9" scaling="Temp"/>
</table>
yourrom.xml
<table name="Cranking Enrichment IPW Adder (Main)" address="5753e">
<table name="Coolant Temperature" address="6124e"/>
</table>
Then just use the appropriate address's for your rom
Old Apr 28, 2010 | 01:44 PM
  #101
fostytou's Avatar
EvoM Community Team
Originally Posted by GST Motorsports
evo10base.xml
</table>
yourrom.xml
</table>
Do you know where I can find the addresses for 52680015-20? I've been looking all over for weeks!
Old Apr 28, 2010 | 04:17 PM
  #102
tephra's Avatar
52680015
<table name="Cranking Enrichment IPW Adder (Main)" address="5749a">
<table name="Coolant Temperature" address="6101e"/>
</table>
<table name="Cranking Enrichment IPW Adder (Unused)" address="56aa4">
</table>
Old Apr 28, 2010 | 05:15 PM
  #103
Tephra beat me to it.
- Bryan
Old Apr 28, 2010 | 05:50 PM
  #104
tephra's Avatar
Old Apr 28, 2010 | 07:12 PM
  #105
Golden's Avatar
FWIW: I'm currently using the AP, so I don't have those tables.
I'm most likely going to swap over once Tephra's mods are out. But in the mean time, I have to have map switching due to running E-85 and possibly not finding a E-85 station.
