Idling problems - solved
Old Apr 17, 2010 | 11:40 AM
xhomm02's Avatar
I had big problems with hesitation and stalling after ECU reset. Changed spark plugs, air filter, MAF sensor, remapped to stock and still the problems.
A man at garage adviced me to take off the intake and clean throttle plate. The throttle plate was totaly dirty with something ugly black. I cleaned the whole TPS part and the problems with idling are gone!
Just wanted to share this experience, maybe it will help someone.
Old Apr 18, 2010 | 01:41 AM
bryanlo's Avatar
thanks for the info..will keep this in mind.
Old Apr 18, 2010 | 02:40 AM
E6-X's Avatar
TPS or TB where u can take out the LICP and clean it instead of taking out entire intake manifold ?
Old Apr 18, 2010 | 02:56 AM
BigT's Avatar
cleaning the throttle body is part of every service for the X.
Old Apr 18, 2010 | 03:46 AM
hotdog's Avatar
Spray methanol; keeps it cleaner
Old Apr 18, 2010 | 06:19 AM
Hiboost's Avatar
Meth would help, I also serviced mine recently after swapping in that prototype intake manifold. It wasn't all that bad but had some buildup on it. The main reason that get clogged up is from running the oil vent back into the intake system. Get a nice crankcase ventilation canister and avoid oiling up your entire intake piping!
Old Apr 18, 2010 | 10:05 AM
xhomm02's Avatar
I did not take out whole manifold, just the air intake box (to have more place for work) and than the pipe from BOV and the pipe from turbo to throttle plate.
Old Apr 18, 2010 | 10:06 AM
xhomm02's Avatar
It is not, according to the service manual.
Old Apr 19, 2010 | 05:07 AM
BigT's Avatar
I called a dealer and asked what is involved in the 15k service and he listed cleaning the throttle body as one.
nytalonTSi
Jan 8, 2019 06:57 AM
chrisff521
14
Jan 2, 2012 01:08 PM
shawnhayes
15
May 1, 2011 08:40 AM
Foolproof
Mar 4, 2010 08:19 AM
EVO8emUp
Feb 7, 2010 10:23 PM
