When WGDC #1A, #1B, and 2 maps are used?
Old Jun 20, 2010 | 02:51 AM
crimson red's Avatar
Hi, All.
I have 2 questions about 2008+ Evo X boost maps.
First, both Reactive & Passive Solenoid Base WGDC has 3 maps, #1A, #1B, and 2. I've been heard that #1A is for SST, #1B is for 5MT. Is this right?
Second, for which gear WGDC #1A, #1B, and 2 be used? Is the 'Low Gear Range' for 1st and 2nd?
Thanks,
Old Jun 20, 2010 | 07:51 AM
Golden's Avatar
1A is high gear range.
2 is low gear range.
I forget what 1B is for. (May be warmup high gear range)
The low gear / high gear is determined by your RPM Crossover value set as RPM/Speed.
The stock value of 145 puts swap point between 1st and 2nd gear. Some change it to 75, which puts you between 3rd and 4th.
Old Jun 21, 2010 | 04:15 AM
Clipse3GT's Avatar
1b is used in higher altitudes usually for a different barometric pressure. I.E. Colorado.
~102 = 1-2nd gear = low gear map
~75 = 1-3rd gear = low gear map
Old Jun 21, 2010 | 05:07 AM
Thanks to you Golden and Clipse3GT, I could understand how the high gear range and low gear range is separated.
Clipse3GT, do you know what condition switches between #1A and #1B?
In addition, I've just found the table names at Cobb Access Tuner site:
http://www.cobbtuning.com/info/?ID=4912
>Target Boost (Load) Table A x x
>Target Boost (Load) Table B WOT x x
>Target Boost (Load) Table C x x
I guess 'Table B WOT' means that #1a is used under condition of half throttle, #1b is used at WOT.
I don't know which is right. I'm confused.
Old Jun 21, 2010 | 05:22 AM
tephra's Avatar
I am not sure that 1B is used for high altitude...
AFAIK (and i could be wrong) 1B is for some sort of error condition...
regardless they are set the same from the factory, and I have ALWAYS seen them set the same... And TephraXMOD's overwrites 1B with 1A anyways (for both normal and altmaps)...
set them the same
Old Jun 21, 2010 | 06:44 AM
Hmmm...Maybe when and how #1b is used is not clear yet.
>set them the same
Certainly, It is the only way now.
Thank you all.
Old Sep 8, 2010 | 04:58 AM
therocket's Avatar
Hi guys, any update about this?
I'm tuning boost right now: for now I set maps #1A and #1B the same, but it would be interesting to undestand when map #1B is used.
Thanks
Stefano
Old Sep 8, 2010 | 06:14 AM
tephra's Avatar
no updates
3VOLUTIONIST
Dec 10, 2016 07:20 PM
okevolutionVIII
Jul 29, 2016 01:13 AM
tenney
May 12, 2016 03:29 AM
robin-evo6rs2
Nov 7, 2013 08:47 AM
Piper747
Mar 26, 2009 06:24 AM
