filter upgrade
Old Jul 4, 2010 | 10:19 AM
JACOB3RD's Avatar
filter upgrade
if i up grade to a cone filter will i need a tune or will i be fine ?
i have a 2010 gsr
thanks
Old Jul 4, 2010 | 10:39 AM
Kracka's Avatar
Which intake are you looking at? Some throw off your AFRs more than others.
Old Jul 4, 2010 | 10:40 AM
migs647's Avatar
Some were designed to run without a tune... it completely depends.
Old Jul 5, 2010 | 11:49 AM
JACOB3RD's Avatar
im looking into aem maybe even one of those $20 auto zone cone filter
Old Jul 6, 2010 | 04:34 AM
tephra's Avatar
why do you want a cone?
best filter is probably a drop in - like a cosworth...
Old Jul 6, 2010 | 10:40 AM
JACOB3RD's Avatar
I only want a cone cause of the bov sound ,but if i need a tune most likely ill be going with a drop in.Will i see more power through a drop in or cone without getting a tune?
Old Jul 6, 2010 | 10:55 AM
migs647's Avatar
You're going to see the same gains between the two. Very subtle differences imo.
Old Jul 6, 2010 | 11:11 AM
JACOB3RD's Avatar
Ok thanks ,now just one more thing will i need a tune?
Old Jul 6, 2010 | 11:16 AM
migs647's Avatar
Depends, some of the intakes were designed to run the car leaner in the first place (were made before the ability to tune the car) (ETS). And if you have a tune, you'd definitely need a re-tune for an intake like that.
If you throw a drop-in on a factory tune, you're good man. If you've been tuned before, and it's a full intake, definitely get re-tuned. If it's just a drop-in or cone filter, you're fine.
Old Jul 6, 2010 | 11:42 AM
JACOB3RD's Avatar
Hey thanks a lot i really appreciate the help. Im gonna be going with a cosworth.
Old Jul 9, 2010 | 03:23 PM
rocksparow's Avatar
Reconnect any hoses or wiring harness connectors and brackets you have disconnected. Re-install the battery tray and washer tank, being sure to reconnect the harness at the washer pump before you have lowered the tray completely and to reconnect the harness up by the check connector and the fluid tube.
