Need help with a definition file
Old Jul 9, 2010 | 04:30 PM
XRims's Avatar
Hello fellow Evo'ers!
I have been troubleshooting issues on the Evo for approximately 6 weeks now, and haven't been able to get to the bottom of it. I am now setup on EcuFlash and am trying to read the rom so that I can do some logging. With a few logs, I'm figuring that some of you will have some opinions regarding what is going wrong.
See attached screenshot, I don't seem to be able to read and I'm pretty sure it's because I don't have the xml file needed for my car. I am using version 1.42.2595 on winxp, and my tuned rom is not locked. Does anyone have a definition file that would work with this vehicle?
For those curious about the issues I'm having...
Seems to be ignition or fueling related. I am running extremely rich, 10-11afr at cruising and varies a lot, idle is very low and sometimes stalls. During high boost and under heavy load (especially 1st gear), the ignition seems to be cutting out (making a machine-gun clicking noise). I have checked all sensors, checked MAF (tested but not swapped), replaced o2 sensor, replaced plugs. Nothing has cured the problem. I had suspected that one or more of the coils had probably gone bad, but I swapped the four of them this week with no luck. I'm at the point where I need to log the car and have you pros let me know what you think...
Thanks in advance for the help, I appreciate it!
Old Jul 9, 2010 | 05:14 PM
Golden's Avatar
Email me your ROM. I'll tell you what it is.
Old Jul 9, 2010 | 09:17 PM
XRims's Avatar
Got your files, I'll give them a run in the morning Golden. I'll keep you posted, thanks again!
Old Jul 10, 2010 | 08:49 AM
XRims's Avatar
I'm now able to read, thanks for the files Golden!
Considering that I'm full bolt-on w/ Kelford stg2 cams, if this is indeed a bone stock tune I can understand why I'm having issues! Mitsubishi probably flashed the car last time I was in. I've asked the original tuner to provide me with the tune file from last summer, I'll keep you posted.
If anyone else wishes to analyse the rom to find out if it is stock, pm me your email address and I'll send it over.
Thx for the help Golden!
mrfred
Sep 17, 2017 06:11 AM
Carvs
Sep 7, 2016 02:21 PM
taron
Aug 7, 2015 12:46 PM
anthony penn313
Lancer Engine Management / Tuning Forums
10
May 17, 2014 02:58 AM
Warrtalon
109
Mar 23, 2008 07:38 PM
