Car trouble...
Old Jul 9, 2010 | 07:49 PM
Methodical4u's Avatar
Car trouble...
ok, so I put the ETS 4" IC on and things were going fine... the AFR was actually better and close to stoich 14.2-14.9 with a lot of 7's flying through there.
Today, all of a sudden as I got the car to where the turbo spools up, the car shutters and the ASC light comes on, the idle shoots up to 2000 rpm (usually 800) and as the car shutters, the SES light (that had already been on) flickers along with it, plus the car just doesn't seem to have as much power. I turn it off for a while and I guess it resets itself, so it's ok, then once again, when I get to higher boost... same thing. Am I hitting fuel cut or what?
Is it possible that with IC install with the 3 port that it caused the boost to go up to much?
I know pretty much everyone is out since it's a friday night lol, but i've been at a viewing all day and have to be at a funeral tomorrow pretty early, plus I don't drink, so no out for me. BUT if there is anyone out there...
I had bought a MBC for tuning purposes, so i'm wondering with the mods that I have if I can just turn the boost on the MBC all the way down and flash the car back to the stock map?
Also, Tephra... how do I get rid of this SES message that started popping up when I got the LC-1?
Old Jul 9, 2010 | 08:01 PM
DTC's are P0420
P1235
Old Jul 9, 2010 | 08:20 PM
ok so the MBC is installed and I went back to the stock map.
Old Jul 9, 2010 | 09:45 PM
tephra's Avatar
yeah your IC + 3port probably caused overboost.
your tuner should (preferably) disable P1235 - although in this case its alerted you to a potential problem..
if you want you can reduce the WGDC's a little ...
P0420 - you need todo the rear02 disable (ecu options 2, bit1 (second last bit))
who are you going to get to tune your car?
Old Jul 9, 2010 | 09:50 PM
Mellon is going to do the tuning. The P0420 code i'm trying to get rid of.. is it in ECUflash or Evoscan?
Old Jul 9, 2010 | 09:54 PM
what about the MBC? If I turn it all the way down, will it keep the car from boosting at all or will it just leave it at stock boost levels?
Old Jul 9, 2010 | 10:14 PM
tephra's Avatar
ecuflash to remove P0420
have you got your wideband hooked upto the rear02 signal wire into the ECU?
you need to work out if your going to use the MBC or 3port or stock setup.
MBC = no messing with the ECU, much less control over your boost curve
stock setup = ok, not great
3port = best IMHO
3port REQUIRES you to half the wgdc's and then slowly increase from there...
Old Jul 9, 2010 | 10:25 PM
3port = best IMHO
no WB is not hooked up to the rear 02, I don't see those options on ECUflash... does it have to be hooked up to the car to be able to look at the options?
Old Jul 9, 2010 | 10:30 PM
yeah I don't see this part... (ecu options 2, bit1 (second last bit))
Old Jul 9, 2010 | 11:09 PM
Golden's Avatar
Mellon is requiring him to use a MBC over the 3-port.
Old Jul 10, 2010 | 03:14 PM
so can someone give me a little more insight into doing what Tephra said about turning off the rear 02 sensor? I don't see what he is saying on my ECUflash program.
Old Jul 10, 2010 | 08:36 PM
Golden's Avatar
Under the section "ECU Options", click the table "ECU Options Set #2"
That table will have an item named "bit.1: Enable Rear O2 Sensor". Tephra wants you to set it to a 0.
Rough_draft
24
Jul 15, 2015 09:31 PM
Methodical4u
29
Jul 9, 2010 05:32 PM
ApexVIII
Oct 11, 2006 03:39 PM
KOEvo
Jul 5, 2006 05:09 PM
cloudy
12
Apr 17, 2006 11:20 AM
